Urgent help does not blow
08.05.2020 20:03 # 1
Karaaa1903
Mrh friends have my 2004 307 and have been having trouble in the heating for the last 2 weeks. He said I did it to the electrician, he said he did not work again, then I connected it to the computer and he said there is an electronic problem and he asked for 300 TL for repair.
08.05.2020 20:03 # 2
ALLEX
The control unit is manual or digital.
If it is manual, look at the heater resistance, fuse and button conductor nails.
If it works but does not heat, check if the thermostat and the temperature level knob function.
If it is digital, unfortunately I have no other advice than insurance control.
I hope you solve the problem soon.
Accident free drives ... ALLEX 2016-11-29 09:01:44
08.05.2020 20:03 # 3
Karaaa1903
They said there is a malfunction in the brain, there is no mechanical distress, electrician said. I could not establish a connection between the heater and the brain, obviously. He called the brain repair 300 TL.
08.05.2020 20:03 # 4
conywolker
[QUOTE = Karaaa1903] They said there is a malfunction in the brain, there is no mechanical distress, electrician said. He called the brain repair 300 TL. [/ QUOTE]
If my brother is just having trouble blowing, don't believe the brain vs story, anyone is doing it to get the masters money.
Open the compartment underneath the steering wheel to the right side, behind the heating buttons, two cables, 3 and 4, go to the bottom and try to move them lightly and let the cables run as soon as the heater is running.
08.05.2020 20:03 # 5
Karaaa1903
Exactly, my brother stayed for 2 days, the electrician has trouble with the car and only blow, then they stop working after they stop and said in the brain of the problem. I will see where you say it, I hope
08.05.2020 20:03 # 6
conywolker
[QUOTE = Karaaa1903] Exactly, my brother stayed for 2 days, the electrician has a car and just got in trouble, they stopped working after they stopped and said in the brain of the problem. I will see where you say it, insallah [/ QUOTE]
This is the heating engine brother, play the cables that go into it
http://s1244.photobucket.com/user/conywolker/media/20160906_200325_zpsp9j2mjut.jpg.html]
http://s1244.photobucket.com/user/conywolker/media/20160906_201027_zps7udcieke.jpg.html]
08.05.2020 20:03 # 7
In addition, the heater resistance may be defective.
08.05.2020 20:03 # 8
Karaaa1903
Thank you very much, Allah. Good luck to your brother.
08.05.2020 20:03 # 9
conywolker
[QUOTE = Karaaa1903] Thank you very much Allah. Good luck to my brother Razi [/ QUOTE]
How happy we are if your problem is solved
08.05.2020 20:03 # 10
JunioR56
Is the climate control unit digital or analog?
If digitalse was not working, was the dot sign flashing next to the degree?
08.05.2020 20:03 # 11
JunioR56
The same malfunction that I read and feel sorry for in this forum happens to me. I'm afraid I enter the site: D
My heating problem was from insurance. I looked at the fuse under the bonnet melted. I tried to replace it with a new one.
