urgent help blackout problem can not be solved
08.05.2020 18:53 # 1
207 arda
I just joined you, good evening everyone ...
207 1.4 hdi vehicle has a blackout problem and no master says anything clear. Injectors of my vehicle were cleaned 4 times rocky Convector was cleaned ... shown to the exhauster. ..turbo checked engine maintenance was done..they are changing this place .. but they couldn't solve. ... yesterday, I removed the vehicle's acismeter plug, the problem was solved, but the performance decreased and the fuel increased ... whether the activator is defective ... after a while the light is on, the light is on and it goes out (illumination lamp) or am I wrong. ..I'm waiting for your help.....
08.05.2020 18:53 # 2
oktan24
Performance improves when acismeter plug is pulled, and the blackout throws in a heavy way
If there is a problem in the flowmeter, your vehicle will not pass 3000
There may be a problem with turbo hoses.
08.05.2020 18:53 # 3
samet2461
Performance software chip tuning may be in the brain of the vehicle other than the original software. the same thing happened to me. Whatever I did I couldn't solve the smoke thing. Connect your computer to the original software and send the latest software. samet2461 2014-11-24 00:13:19
08.05.2020 18:53 # 4
peugeotefe
If you are sure that the injectors are intact, it is necessary to look at egr, it has nothing to do with the air flow meter.
08.05.2020 18:53 # 5
207 arda
Blackbird problem solved egr cancel smoke zero friends. ... :)
08.05.2020 18:53 # 6
suppor
When the master canceled the curve, there was a difference in the acceleration of the acceleration.
