urgent help 2004 307 indicators completely se
08.05.2020 19:10 # 1
mehmethannn
Hi guys,
2004 I have 307 owners. The vehicle was petrol, today on the way home from work, on the trip computer, wrote passenger airbag deactivative d. the airbag light came on on the dashboard and i started the car. then I turned the ignition off and on again all the indicators are gone. I started the car, the indicators revolve, there is no image in any of the air conditioner display trip computer. While the vehicle is running, the air conditioner runs at its fullest speed. There is no problem in the walking of the vehicle, headlights, stop lamps signal lights. there is no problem with the engine. I looked at your insurance, it does not show any problem
I am in a district and no master who understands the peuegot. I am waiting for urgent help on the subject. please can you help. By the way, is anybody in Sivas who knows the master who can understand this work.
I would like to thank everyone very much in advance.
08.05.2020 19:10 # 2
Alicilik
Probably the insurance fuse blown. Check the fuses in the fuse box under the steering wheel.
08.05.2020 19:10 # 3
sezar206
The same happened to me. In the evening, I put the car intact, I started the car in the morning, nothing works on the display. Only warning lamps, signal light indicators etc. work. km cycle gas temperature is not playing at all. I went to the electrician, under the hood and looked at all the fuses under the wheel, they all work. He said you should quit the vehicle, but I could not. I have been using it for a few days. We will look at it for a while now.
08.05.2020 19:10 # 4
sezar206
Anyone with an idea can cause friends. Is there any wire cable etc. that comes to this km hour, there is no problem in the fuses. There is no sign of life in the hands, there is not the slightest play.
08.05.2020 19:10 # 5
mehmethannn
Hello again, friends.
when I run the car in the morning it improved spontaneously. no problems appear. but not my head. I was using it with my wife last week. It recovered after 4-5 hours.
I wonder if anyone has an idea.
I say again, there is no peuegot master in my place. I just got it connected to the computer last night. All fuses have been checked. No fuses.
I would be very pleased if those who share the idea.
08.05.2020 19:10 # 6
pusutr
Within the rules for removing the battery terminal, disconnect the terminal and wait 3 minutes, then re-insert it.
Try it like that.
08.05.2020 19:10 # 7
mehmethannn
I have not used it for 1 year now.
When I say the rules for removing the battery terminal, I did not fully understand what you meant.
08.05.2020 19:10 # 8
mehmethannn
My car recovered yesterday morning. it failed again last night. Again, none of the tachometer speedometer etc. in the dashboard is working when we start the car.
I heard a voice for the first time, when the vehicle was running, before the screens were gone, I heard a sound ...
I am thinking of going to the center of Sivas at the weekend.
or I didn't know if I took it to the service.
can you help me.
08.05.2020 19:10 # 9
pusutr
[QUOTE = mehmethannn] I have not been able to understand the indicators right now I don't understand it for 1 year.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=20338
In addition, problems mentioned by you may be experienced in connector malfunction of the starter motor.
My recommendation is a new starter engine, of course. I do not recommend repair. Because the parts used in its repair are sub-industry and not long-lasting.
08.05.2020 19:10 # 10
muro_60
check the battery and charger
08.05.2020 19:10 # 11
mehmethannn
thank you friends,
The weekend Sivas road appeared.
I hope there won't be a big problem.
It's been a year since I bought the car and it never failed, so I didn't know exactly where to go.
I am looking for a private service, I will go to the service if it is not in Sivas.
thank you again for your help
08.05.2020 19:10 # 12
mehmethannn
Is there anyone who knows special service in Sivas?
08.05.2020 19:10 # 13
peugeot murat
They have holes in the car to install a tube or alarm wiring through the engine to pass the cable through the left wiper grill.
08.05.2020 19:10 # 14
peugeot murat
08.05.2020 19:10 # 15
mehmethannn
Mr. Murat hello,
I haven't been in a few days, I can write today. problem solved.
There are no alarms, tubes, amps in the vehicle so we did not look at it.
They dismantled a box from the bottom left of the steering wheel, I think the fuse box was caused by a malfunction. the problem was solved when he changed the box.
thank you very much everyone.
08.05.2020 19:10 # 16
b.kocer
I think the BSI brain should be well soon
get up to date most people can come to the press is almost a chronic problem
