urgent
08.05.2020 15:13 # 1
duse
2002 307xr gasoline vehicle gives catalytic converter foult failure.
08.05.2020 15:13 # 2
tilbe307
There are many articles in the forum, you can look at them from these titles. and I think you will have an idea.
08.05.2020 15:13 # 3
106_arts
Go through the already written fault, empty it or get a new one if you have the situation.
08.05.2020 15:13 # 4
mimitt
If there is a lpg in the vehicle, disassemble it, install the catalyst, a muffler there, if there is no lpg, you have to buy a new one without this. You can pass the inspection without the original.
08.05.2020 15:13 # 5
When the error comes, your vehicle vibrates because one or more spark plugs ignite incorrectly. There is no condition that the catalytic converter error will necessarily be caused by the catalyst. It can do it from other places, but it can be from catalyst as it is said, which is one of the worst (expensive) scenarios possible. You need to connect your vehicle to the computer and analyze the part causing the error. Do you get this error especially when the engine is cold or not?
08.05.2020 15:13 # 6
mimitt
If I do not know wrong, when the spark plug ignition order changes, the vehicle only lights up the malfunction lamp and does not give a written warning, and this flickering occurs from the first moment the engine starts, as I know from my 406 vehicle.
08.05.2020 15:13 # 7
We do not know whether the engine fault light is on or off. It does not say that it does not burn out clearly that I am superhigh.
Note: I am not saying you are doing the problem from the spark plugs, I am saying that the ignition timing may deviate from the error. This can cause a lot of errors.
Koliva 2011-04-05 22:25:28
08.05.2020 15:13 # 8
Muhammet CAKIR
Everything is making it in the middle, it gives errors about the ignition system even though it has spark plugs, but there is a compression due to exhaust and it gives catalytic error. Göz Kırpma
08.05.2020 15:13 # 9
duse
Gülme Thank you for your answers, I took my car today and got it connected to the device. My master chose to replace the spark plugs first, he said he was in bad condition in the spark plugs. I tried. As long as there are masters of this kind, thank you.
