Unsolved Bsi brain problem
12.06.2021 01:13 # 1
Mcgokhan39
Hello everyone, I just joined you guys, my vehicle 2005 Peugeot 407 2.0i LPG automatic transmission vehicle was misfire from time to time at first, then the engine fault light started to flash and the engine was protecting itself, it was not accelerating, it was mistaking intensely Spark plugs, coils, injectors were changed, the problem could not be fixed while a master was checking. The chassis cable going to the engine was disconnected from the vehicle and when it started, the vehicle became inoperable now, the vehicle does not start, the fan does not ignite, even if we open the door by itself, the fan started to run by itself, the wipers work, it runs out the battery in 1 hour, the vehicle has been lying like this for 3 months. or is there anyone who can recommend a master in Istanbul, I am in a very difficult situation.
12.06.2021 01:22 # 2
karaca61
Call FS otomativ Sariyer, get in touch, I highly recommend it, do research on the internet, get well soon
13.06.2021 02:42 # 3
Mcgokhan39
Thank you very much for the information, I will call tomorrow if anyone has other information about the subject or if anyone has a direct recommendation from Brainci, I would be grateful
10.10.2021 12:48 # 4
eneslan
Hi,
I have the same problem.
2006 Model 1.6HDI executive user. I am the first owner and I have an original 466 thousand km engine. The first problem is that while driving, the parking sensor malfunctions from time to time, while the car is running, it resets itself and the four-stroke flasher works, the interior ceiling lamp turns on, the radio turns on and off, the door locks open and lock again. It appeared to be oxidation, but still not resolved.
Also, the running engine stopped and did not start again. Finally we changed the injector sender and then when it repeated, the injectors were checked. But the injector was not bad. There is no stopping situation at the moment, but we could not solve the electronic problem of the brain or something else.
