Unsolvable Gas Cutting Problem
08.05.2020 16:08 # 1
mehmetk85
Hello friends, I took my vehicle (306XR Platinum 2001), which I bought a month ago, to a familiar master for the week before the feast, I would not, I would not have any problems during the holiday in the car (when there was no problem walking), I changed the parts before the feast and a few needs; ear, bottom swings right left, timing set, charge dynamo belts etc. , upper engine cover gasket, oil - petrol - air filters, transmission oil, engine oil, clutch set, pads, spark plugs. I spent an average of 1250 labor costs. Come on, I picked up the car and left the door in front of the door, and on the day of the feast, the engine malfunction lamp came on at Fatih Sultan Mehmet Bridge, and suddenly it started to cut gas and drown as it stepped on the gas. The vehicle has a sequential weapon lpg. I bought gasoline because it could be from the gas, it did not help, I first took the injector cleaner, used it in gasoline; it still continues. Anyway, we finished the holiday like this, idle is perverted, it stops once in a while, after 3000 cycles, it bursts in gas and gas occasionally, I pull my foot on the gazdana and press it again slowly and it is very difficult in known Istanbul traffic. After the feast I went to the master I had made, they connected the computer, "The FUEL SYSTEM IS VERY RICH", the man says, "Brother said either from the gas or injector", we went to the Atiker service this time; the Atiker Service broke the gas settings, this time the vehicle was less is drowning but his traction is dead, Gasoline is still the same and the malfunction lamp came on again the same day. When I got the answer, "We do not look at LPG vehicles, no service will look," I went to Kartal Sanayi and went to the first master who opened these works without looking at any of them, when I answered 1-2 people that I found it to be an injector, again, a malfunction test, but this He made it with a different device, this time he gave an error as "FUEL SYSTEM IS VERY FAKE". "The throat butterfly is clogged, it will be cleaned, the oxygen sensor will be deposited in the spirit of salt," he said. (What my friends say was always about the throat butterfly). It didn't catch up today, but I'll go back next week; I still could not decide whether to go there or go to Bosh Car Service as I saw in the forum. By the way, when I came home after the last malfunction test, I realized that LPG was disabled and none of the leds on the LPG indicator in the vehicle are lit. I would be glad if you share your ideas about this subject with me. Thank you everyone in advance.
08.05.2020 16:08 # 2
Haksen016
my friend first of all, hopefully the problem will be solved as soon as possible. As soon as you get the car, you should have taken the car quite suitable since you have done such a heavy maintenance and expense. Could there be a problem here during the assembly?
08.05.2020 16:08 # 3
mehmetk85
Unlike yo, I got the market price, the car was very clean and accident-free, it had 60000 km for a 10-year-old vehicle, we replaced the engine cover gasket with the insistence of the master, because it leaked very little from the edges, there was no problem when walking, & nbsp; the real problem now exists:) & nbsp;
08.05.2020 16:08 # 4
Were the parts you installed original? Was there a peugeot emblem on the boxes?
08.05.2020 16:08 # 5
mehmetk85
Sorry for the delay, all the parts are original, meanwhile, the throat butterfly is being cleaned, the situation will be evident in the evening. & Nbsp;
08.05.2020 16:08 # 6
mehmet eren
Do not worry too much about the tube and gas related engine malfunction lamp that my friend usually uses. mehmet eren 2011-09-21 17:45:37
08.05.2020 16:08 # 7
I hope it will be too long, I hope the problem will be solved;)
08.05.2020 16:08 # 8
mehmetk85
Hello friends again
problem solved; Throat Throttle and oxygen sensor were cleaned and gas adjustment increased by atiker for loss of traction. No problem for now & I hope it won't.
08.05.2020 16:08 # 9
Come on late. The heat is cheap. Let's say, let's say that the evil eye does not change ...
& nbsp;
Only the plate does not seem foreign to me. Where are you traveling ??? "Blink" ,
Where do you go to stay in Istanbul. Add to your profile !!!
CeCoLi 2011-09-23 09:05:22
08.05.2020 16:08 # 10
metin
I am very glad to get well soon. I hope you will not go to the caregiver after that. By the way, you are sitting on the Anatolian side since the eagle went to the industry.
08.05.2020 16:08 # 11
mehmetk85
[QUOTE = CeCoLi] Let's be over. The heat is cheap. Let's say, let's not see the evil eye ...
& nbsp;
Where are you in Istanbul? Add to your profile !!!
Tuzla, my uncle, you may see frequently around Kartal - Maltepe on the Anatolian side.
