unscrew
08.05.2020 16:01 # 1
sedatakyildiz
slm 2006 407, but before me, I find the suitable tool for removing the head of the studs on the rim where a bit expensive in the lost service.
08.05.2020 16:01 # 2
It's a pliers-like tool. Is it easy to find? But I think you can easily insert the caps with a tool like a thin-tipped hook-up.
08.05.2020 16:01 # 3
mon
I think it is definitely found in the hardware stores in the industry.
08.05.2020 16:01 # 4
sedatakyildiz
tsk friends asked for 100 lira of service ....
08.05.2020 16:01 # 5
mon
if the service said 100 lira you would get 10 15 lira
08.05.2020 16:01 # 6
Go to an auto tire and ask me what I can remove the wheel bolts, they will tell you. You don't need to buy that apparatus.
08.05.2020 16:01 # 7
orhanax
I think you are asking for the special tool for locked wheel bolts, which is only one at a time. Whereas, it is better to have them in the service and to install normal studs in their places, but the bolt wrench in every hardware store will be sufficient to open the normal studs.
08.05.2020 16:01 # 8
The friend asks for the bolt caps.
08.05.2020 16:01 # 9
MemoTech
Is it so hard to remove the wheel bolts?
First, I put a flat screwdriver on one side and pull it out a little, pull it out on the opposite side and pull it out and pull it out with my hand. I don't know how your caps are.
08.05.2020 16:01 # 10
g-demir
The cover as much as the palm, which hides the bolts of the aluminum alloy wheel it mentions. the key to that cover is missing. it is easy to find, it is found in pieces.
but if there are custom locked studs ...
08.05.2020 16:01 # 11
orhanax
Well, the apparatus for removing the caps is yellow, plastic, something tiny. Even the price of the pile in the service does not exceed 20 Lira that there is no need to remove the covers. It comes out even with a screwdriver or teaspoon.
