Unresolved Tremors Problem
08.05.2020 19:14 # 1
cnrars
Hello there,
I have 307 vehicles, there is an endless tremor problem in my vehicle, after 100 km the steering wheel starts to vibrate, the speed increases as the speed increases, the highway in the day, the tire has not changed, the balance has not been done, no rim on the rim, there is no damage to my vehicle anywhere, what else could it be? I can not fix ..
08.05.2020 19:14 # 2
madblueblacksea
You may have ground balances on the axles to understand this. I think the difference in the balance of the ground is in either axle or brake discs.
08.05.2020 19:14 # 3
samet206
I doubt the axles because there is no driveline that can make other tremors, so I do not know what tremor it is, but if there is no problem with the rim tire balances, the axle comes to mind first, but it can be said in many more things. Except for the events?
08.05.2020 19:14 # 4
sezar206
Axle tulip if it trembles when the gas presses and leaves the gas.
08.05.2020 19:14 # 5
nowaci
Look at the air of the tires.
