Unresolved fault P0805
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
19.10.2022 06:31 # 1
45AFZ919
Salam aleykum everyone, have a good and healthy day. My Peugeot partner Tepee 2018 model Zenith P0805=the location of the clutch cylinder
No one could find the fault, do you have any idea please help
24.10.2022 13:33 # 2
ulas55
hello brother, there may be a switch on the clutch pedal of the vehicle, you should check it, there may be a problem both electrically and mechanically, this is the code of that sensor, maybe it is mechanically loosened or a complete sensor replacement may be required...Ermm
24.10.2022 14:11 # 3
45AFZ919
Brother, it is true, you are very right, but there is no sensor on the pedal, even in these models.
24.10.2022 16:32 # 4
ulas55
In other words, if there was that sensor, the vehicle would not work without pressing the clutch, this code would not work without pressing the clutch in all vehicles, there was a sensor in the debrijay, there was also a hyundai, and the car would not work without pressing it, I just looked, there is no peugeot partner, but it is strange that it gives this error code, I can't say it's a problem in the market. no, they break the service worse than them 🤷 ♂ 🤷 ♂
24.10.2022 17:45 # 5
45AFZ919
Don't ask, bro, we've been in a lot of trouble. The service says that the engine brain is faulty, but we tried the engine, but the malfunction was not cleared again. Some software developer did something from the brain and deleted the fault, but the fault shows itself. It burns 11 liters at 100km. There are problems such as misfire and low traction.
