UNRESOLVED FAILURE
06.08.2025 15:16 # 1
TİMSAH 71
Hello friends, I have a 2003 model 307 SW vehicle. The vehicle has 370.00 km, I had the transmission repaired twice. Recently the vehicle started to give the transmission error again. It gives the error, the revs increase and when you press the brakes when you are close to stopping at the lights, the vehicle moves on its own and if you let it, it will go. The transmission repairman checked it twice with a PC and said there is no error, it is an ignition error. I took it to the engine repairman; coils were changed, spark plugs were changed, throttle body was changed. Finally, he said that the engine was about to go down halfway and there was a fault in one of the pistons. (Meanwhile, another engine repairman said there was nothing in the engine). The last time the transmission repairman looked at it he changed the "TRANSMISSION SENSOR OIL PRESSURE SENSOR AL4". Now the vehicle continues to give the same error and increases the revs when shifting gears. The transmission repairman said that it will be fixed in 500 km. We are waiting for it to fill up. What DO YOU THINK I should do?
26.11.2025 15:40 # 2
pejo5858
The car has a problem with accelerating automatically when the gas light comes on, but your problem doesn't seem to be like that. You could also check the oxygen sensor. Is it overheating? The transmission might not be cooling properly. This is chronic; these vehicles have everything you need, from solenoid valves to signal stalks... It's probably best to pour gas and light it on fire, TD.
