Unresolved Error
04.10.2023 01:28 # 1
tsn.samed
Good luck, there is an electronic fault in my 2012 Peugeot Partner Origin model car. While driving on the road, the wipers turn on and the headlights turn on. When stopped, the engine protects itself. It starts but does not start. I have been dealing with this fault for a year, is there a solution?
05.10.2023 08:51 # 2
There's a problem with your vehicle's BSI brain or engine fuse box, my friend. There's clearly a short circuit. There could be oxidation, etc. Unfortunately, you have no choice but to find a good mechanic. Have you had the fault codes checked?
08.12.2023 00:43 # 3
Blackwall
Immobilizer malfunction, sir. BSI in the driver's cabin needs to be changed. The same malfunction happened to me.
09.12.2023 02:11 # 4
ggitaristt
It could be a BSI fault or a simple loose connection.
