Unopenable sump plug
06.07.2021 10:08 # 1
x571
Thanks to the place where I changed the shock absorbers 2 years ago, he bent and tightened it because it was loose. Now I can't open the plug. I go under the level difference of the garage entrance, there is no situation to get power from the feet. now, how do i turn this on?
3/8 key feels weak.
I have a drill bit from this drill and try it, what's the idea? https://www.hepsiburada.com/bosch-gsb-16-re-750-watt-professional-hammer-drill-p-HRBOSCCHGSB16RE
div>
07.07.2021 11:41 # 2
x571
topic is up to date
08.07.2021 09:23 # 3
talip206
As far as I know, pulling with a pump is not very healthy. Besides, I'm guessing that these little ones will spoil quickly. Because the oil is too dense.
The ratchet will break if you force it with a bite. Easy to open
09.07.2021 15:55 # 4
Berkay Erdinc
As soon as that drill won't work, there are air or electric drills or rechargeable drills to open nuts, you can get them from them.
To open the plug, you do not need a tool. With the pipe, you can extend it and remove it easily
09.07.2021 20:34 # 5
x571
I got it from the pump. It was 250 TL. I heated it to 50-55 degrees until the vehicle switched to LPG. the guide said so. Then I ran it. We pulled it without any problem. Let's see.
09.07.2021 20:41 # 6
x571
Thanks. There was no t arm. ratchet, bite etc are available. I do the little maintenance. While I was changing the shock absorber, the man was walking around with a cool gun under the car because I squeezed a few places. there was a pipe in the attic, there was no ratchet. -5-ah-handleless-double-battery-metal-drill-swivel-canta-torque-screw-nut-insert-p-HBCV00000BOO5N" target="_blank" rel="nofollow">https://www.hepsiburada.com/ jetta-power-tools-professional-36-w-5-ah-steelless-double-battery-metal-shackle-canta-torque-screwing-nut-threading-p-HBCV00000BOO5N
