Understand the Language of Your Vehicle!
08.05.2020 13:55 # 1
Do not bypass problems, check them, go to the service if you can not repair.
- Have your vehicle maintained by authorized persons and regularly, as recommended by the manufacturer.
Do not assume that it will be safe when your car is examined.
- Check the headlamp and tail lights regularly. (You can check against the wall.)
- Check your tires at least once a month. Keep their pressures at the values deemed appropriate by the manufacturer. Do not allow tire tread to fall below 2 mm.
-Make sure that engine oil, brake fluid, wiper water, coolant, power steering and clutch fluids are not missing. Do not wait for the warning lights.
When measuring oil levels, park on a level surface, wipe the dipstick and check the level.
-Make sure your windshield wipers are new.
-Do not clean greasy, sticky or long-term dirt on your windshield with your wipers. This makes the situation worse.
- Always keep your squeegee nozzles set with a pin.
08.05.2020 13:55 # 2
I do the maintenance of the car myself, it is possible to change the oil and oil filter every 10,000 km.
