underside of the mat ???
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 19:00 # 1
emresensoy307
Friends, we changed the thermostadine of my car at the authorized service until a month ago. I realized that the bottom of the ten right mats was completely antifreeze, the vehicle was lost in the water, then the service was brought from the honeycombs of the vehicle, the thermostat was changed ... I went to an electrician before I went to the service.
08.05.2020 19:00 # 2
206quik09
There are radiator drugs, you know, I know that the hole is blocking the places. Maybe you can try it if you want.
08.05.2020 19:00 # 3
byderebey
the same has happened to me twice .. The heater core of my 206 vehicle has changed, the chest has been completely dismantled 150 pounds of workmanship ... now my 307 vehicle has missed water from the comb again, the mat got wet and two days ago, the chest was removed from the bottom before it was removed. If it does, I will have to get the original, it is 350 TL.
08.05.2020 19:00 # 4
berkayakulker
Honeycomb does not crack easily, the problem is because both the gti and the gaskets that I have experienced in this car are hard, you can solve the job for 2 lira workmanship 20 tl 25-30 lira with a good master ... This is done by removing the plastics in the lower right part of the steering wheel (rear part of the gear). operation ... I do not know how many models your vehicle is, but whether it is a plastic gasket or a maximum of 5 years ...
08.05.2020 19:00 # 5
samet206
Gaskets are checked, if there is a problem, it changes, the gasket does not hold much work, antifreeze has been put on, this part of it, but there is nothing in the honeycomb that doesn't crack. I do not want to use the drug is that the vehicle is on sale for 10 days, let me throw the medicine, the man who buys the vehicle will swear when the problem breaks out.
08.05.2020 19:00 # 6
emresensoy307
My friend in the service said, let's order the honeycombs, 350 TL.
08.05.2020 19:00 # 7
muro_60
https://www.peugeotmarket.com/peugeot-206-kalorıfer-radyatoru-valeo,pr-1178.html
45 lira in the sub-industry
350 tl with assembly
08.05.2020 19:00 # 8
emresensoy307
Yes, the tool included 307 jobs.
08.05.2020 19:00 # 9
muro_60
[QUOTE = pug206emre] Yes, the tool includes 307 workmanship. [/ QUOTE] You wrote 206, orj 170 tl side industry, 65 tl workmanship was too much for me.
08.05.2020 19:00 # 10
crazysado
I have 206 im on the bottom seat of the sofor seat, the water remained in the water.I looked at the engine water also reduced.If the problem was pierced by the central heating, when I manually control the central console, I understand that the water comes out, if I remove the console, I will try to insert the console 50 tl. He said, `` With my dad, I managed to handle the console without getting a bit of a master.
08.05.2020 19:00 # 11
ertanakar
After the antifreeze was put in me, water came to the mop .. they said the heater core was pierced .. I researched it on this forum page and without removing the console, the heater core could be taken out of the gas pedal, even though it was a little difficult. I already took the ring of 1 lira in this way. At the same time, he took it to the radiator and tried it in the water and said that there was no problem.
