undercarriage trouble
08.05.2020 19:50 # 1
jackalizm58
Maybe the friends have opened before, but there is no answer, my car is 307 diesel with the model make-up.
08.05.2020 19:50 # 2
akk0212
if there is sound, there is a problem, I have a sound; shock absorber mount, z rods, tie rods changed, sound gone
08.05.2020 19:50 # 3
Adem Kurtuldu
No click noise after 400/500 charges
08.05.2020 19:50 # 4
madblueblacksea
[QUOTE = Adam Saved] No click sound after 400/500 charges [/ QUOTE]
How to summarize better
08.05.2020 19:50 # 5
Barut
This pejo is normal, I laughed well in the morning :) Briefly, I do not know the job, I have not become a master yet. You need to find a solid master, you need to listen to the sound, where does it come from, where is it easier to find. I am sure that the ear of the motor is gone, but the masters cannot solve which one is faulty, one says right and the other says left. I have to change them all at the appropriate time because it is really hard to find a master in the country.
08.05.2020 19:50 # 6
jackalizm58
Well, friends, I went to the village yesterday, I came down on the dirt road, I cooled out of the car. I can not find a solution.
08.05.2020 19:50 # 7
akk0212
then check the tire pressures, whatever value is written on the door, adjust it to that pressure, maybe it is due to it
08.05.2020 19:50 # 8
jackalizm58
if they can find the source of the sound 300 500 i don't care i just get the annoying click
08.05.2020 19:50 # 9
jackalizm58
[QUOTE = akk0212] then check the tire pressures, adjust to whatever pressure is written on the door, maybe it is due to it [/ QUOTE]
We made a friend said a friend.
I wonder if the parts are sound but do they make a sound because they are old?
08.05.2020 19:50 # 10
Faruk
[QUOTE = jackalizm58] friends maybe it has been opened before but there is no answer my car is 2006 model make-up 307 diesel front team is broken with no crushing click on the bottom team no problem, everything is okay, this pejo is normal, it says no sound, it does not a solution [/ QUOTE]
I had the same rattle, it was coming right from the front in 2007 307, it was said that there was nothing in sight, but it was understood that it was one of the shock absorbers because it was very uncomfortable, it was not seen before the shock absorber was removed.
I changed the right, then there was a sound from the left, a little bit from the right, and then I changed it to the left.
It is a very laborious task, but the shock absorbers are being dismantled.
08.05.2020 19:50 # 11
jackalizm58
Let's change them too, let's hope it will be cut off
08.05.2020 19:50 # 12
akk0212
Mine looked solid, the master took it off, waved it and showed it to me, they said it was dead, we changed that way
08.05.2020 19:50 # 13
Faruk
[QUOTE = jackalizm58] Let's change them too, let's see, hopefully the sound will be cut off
As I said as a last resort, there are shock absorber wedges, but it is not understood without dismantling them.
