undercarriage axle and bellows replacement
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 20:19 # 1
serkan 301
hello new 301 1.6 hdi acsess car gold undercarriage passes tumbling as the sound is heard. exsper axles and bellows need to change, how much does it cost and do you know the master you know on istanbul european side
08.05.2020 20:19 # 2
eng uzn
If the axle is broken, my teacher will make a noise in the calcilas and donuses. I think if it is only on bumps, z comes from rot or ball joints
08.05.2020 20:19 # 3
ggitaristt
If the bellows is torn, replace it .. But is your axle really bad? The axle often causes trouble in flattened vehicles.
ggitaristt 2017-05-01 22:54:07
08.05.2020 20:19 # 4
serkan 301
No, my teacher just makes a sound when he passes through the bumps.
08.05.2020 20:19 # 5
serkan 301
Bellows and balls are also a problem, I think. Is there any master you know on the european side of Istanbul?
08.05.2020 20:19 # 6
eng uzn
If you are close to Bayrampasa, I would recommend my master. But first, a rot balancer should be used for troubleshooting
08.05.2020 20:19 # 7
serkan 301
I found the problem and got it done. THE FRONT AMARTOSORES HAVE BEEN DEFECTED, I HAVE CHANGED IT'S NO MORE
08.05.2020 20:19 # 8
Yakotila
Hello, we also bought the 301 Allure 1.6 HDI model in April / 2017 ... I don't know what phrase, did we worry, did we buy a car?
Since the day I bought it, there was a sound called Lok while passing through the bumps. First the left shock absorber changed, it did not improve. Then it was said that it stems from the steering box, the steering box has changed, again it has not improved. Then it was said from shock absorbers, new system shock absorbers came to order from France, we were waiting for them, we were told that the problem of installing new shock absorbers will be solved, we waited, we waited, we waited, after a long wait, it finally came, it was replaced but the sound was not stopped again. Suspension arms have changed as the shock absorbers have changed, but the sound still continues. The bad thing was that before the shock absorbers changed, the sound came only when passing through the bumps made to slow down the roads, after the shock absorbers changed, we started to come in every hole, even at the smallest elevation on the road ... We got cold from the car we took, we became sensitive to the smallest sound, I don't even have it washed. If I have a remedy, a solution for my problem, I want it to be solved, otherwise the devil is poking in different ways, and I do not want to follow the devil.
08.05.2020 20:19 # 9
[QUOTE = Yakotila] Hello, we got the 301 Allure 1.6 HDI model in April / 2017 ... I don't know what phrase, did we get the car?
First of all, welcome to us. My dealer from which dealer you bought the vehicle - abc, if you did not go to fatih peugeota, go there and have it checked. I think you got zero in the production error in the car and you have done a lot of the same problem since you bought it. Talk to the service manager, find a solution for this, otherwise, if you enter the defective product class, your vehicle and sue, you win. Make sure they know this well, they have consumer rights. In order for the problem to be solved precisely, they have to know very well why they had a service conversation with France.
08.05.2020 20:19 # 10
Yakotila
I bought the vehicle from Göral, but since 2500 control, I am going to Fatih Peugeot, the vehicle is following there, thank you very much .. I am satisfied with the service. I will go again today to report that the problem has not been solved ... I think the size of the court, but if there is a solution, I want it to be solved without court.
