Underarm Cable
08.05.2020 19:08 # 1
blntctn
Friends, I turned the car upside down because the airbag lamp was on, I couldn't solve that error, but I saw two cables idle under the driver's seat, I thought it was broken off to cut the seat belt warning (I don't know that this warning feature is in the car). I wonder if the airbag lamp is on because of those cables
08.05.2020 19:08 # 2
peugeot murat
DOES THERE HAVE A SEAT AND CEILING AIRPORT
08.05.2020 19:08 # 3
blntctn
[QUOTE = peugeot murat]
yes ewet 8 is going to be airbag
08.05.2020 19:08 # 4
peugeot murat
POSSIBLE SOCKET UNDER THE SEAT IS GREEN 3 PINS SOCKET AND CEILING AIRBAGIN MAY BE SOCKET SOMETER SOCKET BROKEN CUTS DIRECTLY ADDED MAYBE CERTIFICATE
08.05.2020 19:08 # 5
blntctn
I wonder if the vehicle in my vehicle may not have a seat belt warning cable, but I think it may not be because there is no seat belt lamp on the panel, but I think it is best to take the photo in the evening and throw it out. the pole did not go out 10 minutes later, when I stopped and started it went out, but after 5 seconds it burned again, this event happened 2 times, which means it could be in the armpit. but auto electrician tied to the computer said com2000 is giving error.
08.05.2020 19:08 # 6
peugeot murat
[QUOTE = blntctn] I wonder if the car in my car may not have a warning cable because it doesn't sound because I don't think it may be because there is no seat belt lamp on the panel, but I would like to take a photo in the evening and throw the socket under the steering wheel. I said I did it, but the lamp did not go off, when it stopped 10 minutes later, it went out but it turned on again after 5 seconds. but auto electrician connected to the computer said com2000 is giving error. [/ QUOTE]
SOCKET COLOR MIND
08.05.2020 19:08 # 7
blntctn
[QUOTE = peugeot murat] [QUOTE = blntctn] I wonder whether the car in my vehicle may have a seat belt warning cable, but I think it may not be because there is no seat belt lamp on the panel, I think it is best to take a photo in the evening and also the airbag lamp is on, another friend from here steering wheel I opened the box underneath and told me to disconnect the plugs, I did it, but the lamp did not turn off, when I stopped and started it after 10 minutes, it went out, but it turned on again after 5 seconds. but auto electrician connected to the computer said com2000 is giving error. [/ QUOTE]
SOCKET COLOR MIND
I don't remember if I take a picture and throw it in the evening?
08.05.2020 19:08 # 8
peugeot murat
05358461001 FROM VATSAP AT ATTEMPT
08.05.2020 19:08 # 9
blntctn
[QUOTE = peugeot murat] 05358461001 VATSAPT AT AT KEYİFSİZİM EVE GEÇİYOM [/ QUOTE]
OK, I recorded my teacher, I will throw it away immediately.
08.05.2020 19:08 # 10
xmen
there is probably a problem with the airbag wrap.
08.05.2020 19:08 # 11
blntctn
[QUOTE = xmen] probably a problem with the airbag wrap. [/ QUOTE]
How is it when you say airbag wrap :)
