|   | Under the rear seat of the 206 vehicles getting wet |
| 08.05.2020 16:24 | # 1 |
|  amonse | |
| 08.05.2020 16:24 | # 2 |
|  xpyhre | |
| thanks for the info.     | |
| 08.05.2020 16:24 | # 3 |
|  amonse | |
It does not matter ... we all do unnecessary expenses in vain ... at least not only when there is a malfunction, but it is useful if we write our experiences when we solve the situation ... They said :) I took the bottom of the antenna for 10 TL, mounted it with silicone and got the job done :)
| 08.05.2020 16:24 | # 4 |
|  tlp | |
I have that same problem. I pray that he doesn't rain. I thought I was getting under the car. I hope it is only from the antenna part
| 08.05.2020 16:24 | # 5 |
|  tongucuk | |
my friend sunroof was original or changing later, there is a barrier in istanbul is doing very affordable repair & nbsp; and permanent repairs lifetime & nbsp;
| 08.05.2020 16:24 | # 6 |
|  xpyhre | |
| [QUOTE = ramazanturan81] my friend sunroof was in the original or later, there is a barrier in istanbul is making very affordable repair & nbsp; and permanent repairs lifetime & nbsp; [/ QUOTE]   Hello teacher, I have a 206 gti glass to be mounted on the sunroof in my vehicle. days. strong> font> p> | |
| 08.05.2020 16:24 | # 7 |
|  tlp | |
When my friends went out to change the oil of the car the other day, they lifted the car with a lift and said, let me check the bottom part for the opportunity. What I see in the bidet is a slot in the back of the right tire on the right (water-filled area), and it deepens inclined towards the rear trunk. I said let me look at the other side, the same is there, but it is closed with something like a grill or a filter, so water is taken to prevent water, etc. I guess I figured out where the vehicle got au. In dense rain, it passes through that channel to the trunk. Afterwards, the vehicle is moving through the small ducts to the armpit because it is moving (I understand from the trace that the water has flowed). So if you understand that if you don't control this situation, I would say check it out. It may be difficult to see if you downloaded it from torsions. You have to remove it).  I hope it will solve this problem | |
