Under Mirror Led Application
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:17 # 1
werty
Hello friends,
& nbsp;
You know under-mirror lighting that it's very fashionable right now. Well, it is necessary to adapt to the fashion. If there are friends who try this, & nbsp; they will be very happy if they know how to do it. & Nbsp;
thanks in advance. div> & nbsp;
and
& nbsp;
werty 2013-01-16 17:19:44 < / editdat a>
08.05.2020 17:17 # 2
Alicilik
It is a workable work but it is difficult to put a line inside the door.
Never mind the led in the deal, it looks very protruding. I brought it from the product in the second link. The purpose of these leds to be installed in the trunk is actually reversible and illuminates the vision, but they can be multi-functional: D
http://forum.peugeotturkey.com/forum_posts.asp?TID=25591&KW=3w+led&title=206-gndz -led-almas-soon
Review the title. I'm going to do the daytime led in the near future.
Also, the back of the second led is about 2cm screw and is not cut. It is necessary to examine how the mirror is mounted.
08.05.2020 17:17 # 3
blinddark
I made it to my car, it was easy because it was a TV on the hill, but it was a bit of a challenge to find the electricity from the cables. It is not difficult to get a cable from the tape's electricity. it doesn't even hold it. I used white led at first, it doesn't bother at night on the city light road, but if the road is dark, it blinds, I use red now. I am very pleased, it looks stylish and provides illumination that does not disturb. It looks super on the gear. The moment I press it, it starts to burn, I get off the car and lock the doors, it goes out after about 1 minute, it provides constant lighting while driving.
08.05.2020 17:17 # 4
Alicilik
[QUOTE = blinddark] I made it to my car, it was easy because it was a TV on the top, but it was a bit difficult to find the electricity from the cables. You can pull a cable from the tape's electricity to the ceiling. cp. it doesn't even hold it. I used white led at first, it doesn't bother at night on the city light road, but if the road is dark, it blinds, I use red now. I am very pleased, it looks stylish and provides illumination that does not disturb. The moment I press it, it starts to light, I get out of the car and it closes after about 1 minute. It provides continuous lighting while driving [/ QUOTE]
My teacher, the submarine light you call. It is usually done in the evening to add a dim atmosphere to the vehicle. It has a description in the link below.
http: //www.peugeotturkey.com/nasil_yapilir.asp?MakaleID=48
If I think of a friend, he wants to make a lighting under the rear-view mirrors as in 308-c3.
You get electricity from either bsi or ceiling lamp But it will be difficult to pass it through the door to the mirror and install the LED on the mirror. And if you need to remove the door in the future, wow.
But it would be nice. I also plan to make it into the door handles. Now I will order ICE bLue leds.
08.05.2020 17:18 # 5
werty
Just like my teacher said, I want to apply lighting under the mirrors outside. There are people who did, I had the opportunity to review. but it is a very laborious heat .. the bottom of the mirror will be pierced and the line will be passed.
The most logical ceiling lamp came to me. If I can find the method of application & nbsp; I will share it. If not, I'll be going myself now =) ... take pictures and put them ...
