unable to change dipped beam
08.05.2020 21:28 # 1
Bayer
https://hizliresim.com/MR96Q9"> https://i.hizliresim.com/MR96Q9.jpg" >
Guys, the dipped headlight had to be replaced. We couldn't remove the socket. We did not want to damage the cables or any kind of sensitive. How do we have a light bulb?
08.05.2020 21:28 # 2
Save the metal wire from the hooked part on top it will come with the bulb. sometimes it is hard to disassemble, hodja.
08.05.2020 21:28 # 3
ismailkaya
Take a good look inside the wire.
08.05.2020 21:28 # 4
Bayer
I removed the wire. The bulb came out with the socket, but I cannot separate the socket from the bulb. The end of the socket looks like it has melted and stuck. Bayer 2020-02-18 14:19:52
08.05.2020 21:28 # 5
[QUOTE = Bayer] I removed the wire. The bulb came out with the socket, but I cannot separate the socket from the bulb. The end of the socket looks like it has melted and stuck. [/ QUOTE]
then you will change the new socket pickup from auto electricians. It's not a very expensive piece. 15-20 TL but definitely use lei and macaron.
08.05.2020 21:28 # 6
Bayer
Since the inserted light bulb was installed, it also melted the socket from the heat. so I couldn't get it out. bulb and socket replacement was made.
08.05.2020 21:28 # 7
Thank you for the information.
