Turns On Fan When Cold Engine Runs?
08.05.2020 18:38 # 1
34zk9340
My friends vehicle I stopped working from night till night and run on cold engine again.
08.05.2020 18:38 # 2
Ali1905
temperature sensor is broken, let's give it to you immediately :)
http://forum.peugeotturkey.com/forum_posts.asp?tıd=35625&title=satilik-206-orj-fren-musuru-ve-su-sicaklik-sens is
08.05.2020 18:38 # 3
34zk9340
overheard he changed it 2 times but still continues
08.05.2020 18:38 # 4
34zk9340
Master called, now 2 times, the movement sensor has changed. When you do the same again yesterday, there is a problem in the brain.
08.05.2020 18:38 # 5
Serkan
I can do it from the socket of the temperature sensor.
08.05.2020 18:38 # 6
34zk9340
In the vehicle industry, the brain is being controlled. The temperature sensor has changed two times, the question still continues. There is no other option but when connected to the computer, the temperature of the customer is malfunctioning.
08.05.2020 18:38 # 7
popeyes
[QUOTE = 34zk9340] searched for the master, now 2 times the movement sensor changed, he says that the brain has a problem when he does the same again yesterday? [/ QUOTE]
My teacher recently shared a post in the forum they could not find the fault of my car. he did not perceive the heat sensor and was working hard. stop working when running
all the masters said the brain was defective. But I did not believe it, because if the brain is defective, it does not do 1 or not, always pay attention to it, so be sure that the defect will recover and not break.
Anyway, I know where my fault came from. The rainwater dripped on the sockets that went to the injection brain and had a chassis there and tormented me for 1 week in a few days,
I wrapped it now wrapped up, thank goodness.
Do you have any water dripping on the cables going to the injection brain?
08.05.2020 18:38 # 8
popeyes
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=35476&title=beyin-arizasi-saniyorduk-cozul
look at this
08.05.2020 18:38 # 9
Foxfire
20-30 pounds from the thermostat changed it
08.05.2020 18:38 # 10
murat222
