|   | Turning the steering wheel to the right makes a sound. |
| 08.05.2020 18:37 | # 1 |
|  ekinoks44 | |
| 08.05.2020 18:37 | # 2 |
|  Advantan | |
Is this the sound you say?  [TUBE] wscuusgdfl4 [/ TUBE] | |
| 08.05.2020 18:37 | # 3 |
|  ekinoks44 | |
Yes, such a slight click is coming.
| 08.05.2020 18:37 | # 4 |
|  ekinoks44 | |
no friends with an idea    | |
| 08.05.2020 18:37 | # 5 |
|  ByHack | |
When I noticed that my difference suddenly turned in my car, the steering wheel looks like this, but a barely understandable click sounds. I think probably from the front teams (from the swing or rot).
| 08.05.2020 18:37 | # 6 |
|  pusutr | |
That sound comes from the axle. the socket is probably worn. need to change.  | |
| 08.05.2020 18:37 | # 7 |
|  D.EAGLE | |
me doing right right clickkkkkk what do you think friends are?  | |
| 08.05.2020 18:37 | # 8 |
|  popeyes | |
[QUOTE = ekinoks44] Hello friends .. I have a Peugeot 206 XT automatic transmission vehicle. There has been a problem for a week, turning the steering wheel one turn to the right, a click-like sound from the front. I checked the steering oil, there is more. Do you have any idea why the problem is caused? [/ QUOTE]   My teacher had a car in my car. When I turn the steering wheel, it would sound like a plug.   but he always came in the same part   There was a master, raised the car, turned the steering wheel and said wait when he heard the click.   He tightened a screw, he did the same thing several times and he did not do it again, but I don't know what screw it was  | |
| 08.05.2020 18:37 | # 9 |
|  fætih | |
reduce tire pressure slightly. make the front around 30. It is most likely that the rod rod makes it from the swing. I hit 34 tires, the air was coming in me, I dropped it :)   If he gets up from the axle he hits it as a plug. Take off hard, if there is sound, it is gone on the axle ...  | |
| 08.05.2020 18:37 | # 10 |
|  aremtu | |
I have the same voice. If I turn the steering wheel completely, there is a clicking sound and the abs lamp is on. Then it goes out by itself.
| 08.05.2020 18:37 | # 11 |
|  MasMavi | |
Friends 2004 Md. I have 307. I have the same voice as follows: When my vehicle is parked, after turning the steering wheel one turn to the left, it sounds twice as clicks. The same sound does not come when I turn the steering wheel to the right, during takeoff or on the move. He started making this sound after changing the tires. it was not before. I haven't been to the service or a master yet. Why does anyone have this sound idea?
