Turning Around With The Hand Brake |
| • Homepage » PEUGEOT MODIFIED PLATFORM » User Guides | |
| 08.05.2020 15:14 | # 2 |
voodoo |
:))) ii share
| 08.05.2020 15:14 | # 3 |
Can we do it with 307, Colonel brother?
| 08.05.2020 15:14 | # 4 |
Oh my brother, don't try anything like that. In general, he writes that you will not try anything under such things. Look, it should not be tried except for the masters who have written here ...: DD
| 08.05.2020 15:14 | # 5 |
insomnia |
I had an intermediate eagle, when I turn between the street, there is no need to steer left or right. If it is empty, give it a light gas. I pass through the slalom between the columns in my istanbulforum :)))
| 08.05.2020 15:14 | # 6 |
I am very pleased with the 306 's best handling :)).
| 08.05.2020 15:14 | # 7 |
insomnia |
[QUOTE = cecoli] The 306's handling is one of the best sides :)) I'm very pleased with it. [/ QUOTE] Master, you're right, but I must admit, I think it's a braking disability |
| 08.05.2020 15:14 | # 8 |
I had a Ford Taunus, what side would give it when it gives off the gas, 307 is not possible automatically. I was blown off :)
| 08.05.2020 15:14 | # 9 |
[QUOTE = insomnia] [QUOTE = cecoli] The 306 's handling is one of the best sides :)) I am very happy with it. [/ QUOTE] Master, you're right, but I must admit, I think it's a braking disability [/ QUOTE] I think it is valid for your vehicle 4 disc brakes, abs 5.0 and electronic brake light are very hot. Also, your disks are 247mm and mine is 266mm. there is cap difference. for example gti ske 283mm
| 08.05.2020 15:14 | # 10 |
insomnia |
[QUOTE = cecoli] [QUOTE = insomnia] [QUOTE = cecoli] 306 's handling is one of the best sides :)) I'm very pleased with it. [/ QUOTE] Master, you're right, but I must admit, I think it's a braking disability [/ QUOTE] I think it is valid for your vehicle 4 disc brakes, abs 5.0 and electronic brake light are very hot. Also, your disks are 247mm and mine is 266mm. there is cap difference. for example gti ske 283mm [/ QUOTE] master ass no head coping dynamically in the car doing very well on wet ground I have a pretty good bit of abs compared to the old one |
| 08.05.2020 15:14 | # 11 |
[QUOTE = cakici9843] Can we do this with 307, Colonel brother? [/ QUOTE] Free to try ... But I do not recommend it. |
| 08.05.2020 15:14 | # 12 |
boranaydogmus |
I want to ask 206 users something. When I apply the handbrake in my vehicle, it pulls down one side when I try to get up again as if it is holding one side and the other side does not. Are all the 206's like this?
| 08.05.2020 15:14 | # 13 |
[QUOTE = boranaydogmus] I want to ask something to 206 users. When I apply the handbrake in my vehicle, it pulls down one side when I try to get up again as if it is holding one side and the other side does not. Are all the 206's like this? [/ QUOTE] then it does not hold 2 wheels. I know very well what you said. One side of the vehicle is contracting and the other side is not. The reason for this is that it does not hold an equivalent on both sides. you should look at the handbrake. If you see the examination soon, you can see this difference very clearly in the brake test on the canvas ...
| 08.05.2020 15:14 | # 14 |
boranaydogmus |
[QUOTE = cecoli] [QUOTE = boranaydogmus] I want to ask something to 206 users. When I apply the handbrake in my vehicle, it pulls down one side when I try to get up again as if it is holding one side and the other side does not. Are all the 206's like this? [/ QUOTE] then it does not hold 2 wheels. I know very well what you said. One side of the vehicle is contracting and the other side is not. The reason for this is that it does not hold an equivalent on both sides. you should look at the handbrake. If you see the examination soon, you can see this difference very clearly in the brake test on the canvas ... [/ QUOTE] There is no examination, because I have not used pug before, I said to the ones who know that the original is like this. then we have the examination time done. thanks. |
| 08.05.2020 15:14 | # 15 |
forewer_fb |
my old car, 1997 306 diamond du handbrake did not hold the handbrake, it was fun, but it had a lot of damage to the car, but in an empty and convenient place (I usually do a lot of time in the empty squares of uludag university at university time :) everywhere is covered with snow, and also a lot of fun on the grass :) )
| 08.05.2020 15:14 | # 16 |
I was doing a lot in my father's 1986 model lada. I gave my car money, I can't break it. |
| 08.05.2020 15:14 | # 17 |
What a pity, isn't it a pity? |
| 08.05.2020 15:14 | # 18 |
asil16 |
wouldn't try: D
| 08.05.2020 15:14 | # 19 |
i never tried :)) i try it :)) i love my car |
| 08.05.2020 15:14 | # 20 |
The handbrake is not thrown, but it cannot give pleasure from a rear-wheel drive vehicle. If it is your first attempt, you need to practice a bit in a traffic-free area. Remember to turn a direct junction with the hand brake.
