Turn signal lever and headlight 307
08.05.2020 20:25 # 1
Darke
Slm friends, when I run my car, my lights turn on the headlights, even though I put the lever to the 0 position, I do not go out, I have to burn the parks by force, the headlights turn off when the car stops and put it in the position of 0.
08.05.2020 20:25 # 2
yali301
I have a 2005 model 1.6 Gasoline 307 vehicle. I bought it about 3 months ago. When I was a 12-year-old machine, Ben had a similar problem with his signal arm. The signal arm did not work (stuck) when I turned on the headlights, even made chassis and covered the headlights etc.
As far as I can see, this is a chronic problem in peugeot. That arm is somehow malfunctioning, making chassis, and most say that the entire hub needs to be replaced. Yesterday I went to Güngören-Bağcılar Oto industry and got a price from the particle with the last 8 digits of my chassis number, they raised a price of 1100+ TL.
A friend in the tracker, Güngören Bağcılar Oto Sanayi, directed to Şimşek Oto in 19th Block no: 6. Zübeyir and Şeyben are masters. He looked, checked and said, we'll replace it with 1 year warranty. It gave 1-1.5 hours. It would not be right for me to quote, but they changed it to a very small figure besides 1100+ TL. At that time, I saw that they changed 4 more signal arms :) So it seems impossible to get rid of it.
You find the piece on the Internet, but there is a sale. I just did not know if the signal arm would be solved if I changed it. There is even a replacement video on Youtube, but you also have the risk of calling an attractive in the steering wheel :) I did not take that risk.
I was in the forum for the first time to share my experience about Signal arm shortage I saw your sharing :)
08.05.2020 20:25 # 3
In only 307 many peugeot 206-207-307-407s, chronic problem 1100 TL flying element really takes the name of the part pp2000 (headlight signal lever) zero around 500-600 TL and as replacement work, it takes between 50-100 TL. It will cost around 300-400 TL.
08.05.2020 20:25 # 4
yali301
Master, I saw the numbers you said on the internet. The model with the radio control arm in my vehicle is the 3-arm. I called the Mepa authorized service and they said we will give the price according to the chassis number. In Güngören-Bağcılar auto industry, Şener auto said that we will only look at the last 8 digits and said 1,600 odd to your model, which is 1.6 petrol. I hope it has only been 1 day :)
08.05.2020 20:25 # 5
uzunca961
[QUOTE = yali301] Master, I saw the numbers you said on the internet. The model with the radio control arm in my vehicle is the 3-arm. I called the Mepa authorized service and they said we will give the price according to the chassis number. In Güngören-Bağcılar auto industry, Şener auto said that we will only look at the last 8 digits and said 1,600 odd to your model, which is 1.6 petrol. I hope it is only 1 day :) [/ QUOTE]
Similarly, it happened to me. In me too, the signal went out by itself.
As Soner puts it, it's hard to fix the piece unchanged.
Having 3 arms does not change anything. The two arms on top are fixed on that piece. signal and wiper.
the radio arm is already in plug and play style. Don't find it, I did it.
08.05.2020 20:25 # 6
hozer33
yes, this sometimes sticks on the pejo like chronic, does not signal, it shuts itself off in the evening, etc.
08.05.2020 20:25 # 7
Nightmarecr
You can get a maximum of 40 tlyes from Ali Express with free shipping. In 20 days. Be careful if you push the steering airbag out of the holes in the back, be careful, either put the airbags in the off position or remove the battery terminal, the rest is easy. You remove the steering wheel and take the com2000 out. You can open the nails carefully and attach the new handle. Personally, I changed it. It was just fine.
08.05.2020 20:25 # 8
ggitaristt
[QUOTE = Darke] Slm friends, when I run my boredom vehicle, the headlights are on, the headlights do not go out even though I put the lever to the 0 position, and I continue to burn the parks by force, the headlights turn off when the car stops and turns to the 0 position.
A bit of a whirlwind.
In my car, I cannot switch off the headlight in the evenings .. But the reason is not a malfunction.
I think your friend's headlight sensor is broken.
08.05.2020 20:25 # 9
Cemm
check your headlights may have remained in automatic setting I think the signal arm was not turning off when I gave a signal on 2004-07-2019, the signal arm was not closing, I did not close it manually, I went with this problem, I went 140 tons in the industry, I bought a signal arm in the industry, I worked in 150 TL. There are some 307s of signal movies that have improved to me, I still don't know why it was in the heat because mine was not filmed 🤷 🏽 ♂ & nbsp;
08.05.2020 20:25 # 10
Ferhat5834
if the vehicle has an automatic headlight sensor. The battery will only turn on the ignition and the battery lamp will light. Hold the button on the top of the turn signal arm for 3 or 4 seconds and the automatic headlight will be disabled, the problem will be solved. The cause of the problem is that the headlight sensor is damaged or not detecting at night and it lights continuously.
05.07.2020 19:45 # 11
Taksi
Headlight sensor is defective, take help, if you want help 05372748676
