turbocharged faults 2
08.05.2020 14:18 # 1
turbo27
sometimes we have the problem of smoking in our vehicles .. this smoke throwing event sometimes becomes black, sometimes white and bluish ... in these cases, the water should not throw the turbo immediately, the turbo has an effect on the smoke of course, but it causes smoke in other malfunctions together with the turbo. ..
black smoke throwing
There is a lot of reason to smoke black smoke. Firstly, diesel pump and injectors are the parts that need to be primed in this regard. However, the air filter and the diesel filter are clogged. A balance of air and fuel must have a density and quantity. Completely deterioration of air flow meter causes black smoke, irregular advance adjustment, valve and non-worn wear, injector pollution unbalance causes black smoke in all dies, egr valve pollution.
throwing blue smoke
The turbocharged oil outlet pipe is clogged because the turbocharger in the turbocharger may not have an excessive outlet in the turbocharger.
