turbo whistling sound
08.05.2020 15:16 # 1
sagondragon
Hello. my name is Ahmet, I would have a question about the 207 1.4 hdi motor vehicle my wife used.
The vehicle is still at 3000 km, and since the first time it was taken, the whistling sound is very disturbing in the 2000/3000 rpm range (2-3 and 4th gears in separate rpm). I know that I have been using a diesel vehicle for a long time, which is a more disturbing sound than the current turbo whistling sounds. This sound is constantly coming in the same times. The service (I got two separate services) is looking at the vehicle under warranty, the sound is not normal, they say let's look at the turbo, but they cannot find the solution. Finally, they come from Pejo Turkiye and say the sound is normal and take your car. During this 3-month period, I had the chance to test 3-5 207 diesel vehicles, but this sound does not come from any other vehicle. I would be very glad if you could send the communication information of someone who has a recommendation or specialized in turbo. Best regards.
08.05.2020 15:16 # 2
Serhun
I saw that the Bipper vehicle had turbo failure at such low mileage. There was also sound, but first he sweated in the snail part. But he says that you are not turbo or service turbo. In this case, it comes to my mind that the steering system in the vehicle system should be checked with alternator air conditioner compressor etc.
Get well soon.
08.05.2020 15:16 # 3
sagondragon
Thank you very much for your reply. In fact, in my opinion, the problem is caused by turbo (I tried to show that it was a different sound than the normal turbo whistling sound). The people who tested the car outside of me say that the problem is turbo-sourced and everyone has a different theory. He calls the turbo at the service and says that they check every evening and try. When there is no problem, Pejo Turkiye officials come and it is said that there is no problem. Clearly, I did not have much confidence in the masters in the service. Maybe a problem that could possibly be dealt with us came across us, but I am looking for a solution as much as possible. tsk
08.05.2020 15:16 # 4
sagondragon
I can also describe the sound as water:
On high faces, if you reach 150 km or more, there is a sound that is connected to the face where the wind comes from outside. A sound is heard in 207 of us. However, the sound does not come out of a certain point on the tachometer. The gear is ticking in gear and speed change, until the next interval in the next gear.
08.05.2020 15:16 # 5
ADM
the spindle scatters the sound of the turbo.
08.05.2020 15:16 # 6
sagondragon
I'll thank ADM. One of my friends said that the turbo shaft was broken. When I arrived at the authority in Pejo Berke, he said that the C.tesi took the vehicle and said that the problem might be due to the miles. We started to hear this sound when the vehicle, which is an interesting one, is just 200 km away, and the sound has been going on ever since. The towing of the vehicle is flawless. I do not know if there is an official connection with the forum Pejo Turkiye, but I want everyone to be able to present it, I was disappointed at Peugeot about the warranty. If the Emınımkı vehicle was older than 2 years, the turbo would be replaced. Because of this, I would like one of your dearest friends, I would like you to see the industry, special service, etc. Understanding the problem by directing it somewhere. Thanks again for the time you read and read and for the replies.
08.05.2020 15:16 # 7
Serhun
It should also check the oil level of the vehicle that has a turbo problem.
The deterioration of turbo can be oil, manufacturing burr, fuel, blades, shaft defect etc. I think it would be easy to try to solve the warranty with the most beautiful authorized service records.
08.05.2020 15:16 # 8
furkan
the balance is gone, go to the service, I will take you to court, call your right, turbon is guaranteed to die.
08.05.2020 15:16 # 9
ADM
I hope that they will help me in the repair and change of the name number in the mind of the Anatolian side, because there is a turbocus in the Göztepe industry, hacıoğlu.
08.05.2020 15:16 # 10
ADM
there is a good master there he understands good ..
08.05.2020 15:16 # 11
furkan
Gantili car never goes private
08.05.2020 15:16 # 12
goktug
If you pay attention in this forum, we encounter the titles of friends who have problems with the turbo sound once a week. really it is. my turbo is also pretty crowing. even those who use turbo in other models make over-interpretation of my car's turbo sound. but the master called me normal. Maybe peugeot's turbos are working out loud, guys. Everyone who writes says there is no change in traction and performance. same with me. Are we wrong about the turbo and the maximum sound that turbo should make? (Just an idea)
08.05.2020 15:16 # 13
furkan
if he makes an ambulance, he is about to die
08.05.2020 15:16 # 14
ADM
I do not understand where you can find such strange things, this is not the police station, it is turboo. It is not for the peugeot in diesel vehicles. opel vectra 2.2 turbo diesel two times turbo changed ...
08.05.2020 15:16 # 15
furkan
When the gas is loaded, the sound increases and the gas decreases, so 1.2.3. If you want to sound like an ambulance, until you put it in gear, ask this service to a service, let's see my police radio.
08.05.2020 15:16 # 16
sagondragon
Furkan Bey's guaranteed vehicle as you change it to go to the special service and see the transaction is basically unreasonable and a negative situation in accordance with the warrant specifications due to consumer. The main purpose here is to prevent Peugeout from going to a justified defense in the future consumer court and expert reviews and by other experts. As a result, there will be no white collar people on the court appointed by the court. It will be one of those who do this profession. I would be glad if those who knew about the communication information of Hacıoglu or Adem Usta; I want to show them the vehicle and be sure of one hundred percent. To sum it up, let's say: the consumer courts have a misleading illusion in our society as the consumer is generally with the consumer. What needs to be done here depends on the necessary support of the criteria that will be the subject of the case. Thank you to all my friends. If there are important developments related to the subject, I will try to give information to you. tsk
08.05.2020 15:16 # 17
ADM
brother same problem i had car also turbo changed just whistle like cat sound if your car is agarti go go do not ever deal with the service two words say you are interested if you want peugeot angle there is festive master there text master there authorized service where is your vehicle
08.05.2020 15:16 # 18
sagondragon
Our vehicle is the ebony, and if I go there again, it will probably be very unpleasant. Let's try the bitterness, then you can see that the people you call really help. Has ADM changed under the vehicle's turbo warranty? tsk
08.05.2020 15:16 # 19
sagondragon
I went to Hakan Usta at Peugeot Efe and thank you very much. Aside from the masters in other services, Hakan skillful is really good at the heat and extremely good. The vehicle went into service today, and after testing the vehicle in Hakan Usta, he made the research and said that by inserting the turbo, the "turbo balance" adjustment would be made again and the problem would be eliminated in this way. We'll wait and see.
08.05.2020 15:16 # 20
ERKAN52
brother, this sound is a bit between 100 and 1500 rpm.
Page : / 2
