turbo whistling sound
08.05.2020 14:58 # 1
furkan
my friends vehicle 2005 model 307 1.6 hdi look 110 hp my question will be that when my car is loaded on the gas pedal, a sound like a soft whistle rises with gas, the sound slows down when the gas is released, it is not heard so obviously it is heard when it is heard, it is heard in the private service. He said that this voice is normal. I did not make it look at the authorized service. The guys are changing the solid part.
08.05.2020 14:58 # 2
Haksen016
They call this slight whistling sound normal in diesel vehicles.
08.05.2020 14:58 # 3
oskancomputer
if this sound is not very normal, it will be abnormal anyway. have nothing to be afraid of, enjoy it brother
08.05.2020 14:58 # 4
peugeot murat
There is a balance in the turbo that we call sound balance, it makes sound when it breaks, it is not just a problem.
08.05.2020 14:58 # 5
furkan
[QUOTE = peugeot murat]
yes, as you said, I made the master look at the room, he talked about the balance and also it is intermittent from the aluminum shield screws underneath the turbo.
We also got zero fort transit in 8000 km, I looked today and when I gave the gas, there was a whistling sound.
08.05.2020 14:58 # 6
muratgulen07
I asked this sound in 96000 bzm car, said from the turbo said 120000 turbocharger ...
08.05.2020 14:58 # 7
Haksen016
They say the sound of air coming from the wings.
08.05.2020 14:58 # 8
Is there a problem in the traction of the car if the traction is a little cumbersome and the fuel consumption is positive is the picture of the turbo ending bro
08.05.2020 14:58 # 9
muratgulen07
There is no problem in the shoot, does it have anything to do with fuel?
08.05.2020 14:58 # 10
furkan
In the city 50 TL 3rd gear is very rare, always 1 and 2 stop and I make 250 km out of town I made 480 km with 50 TL
08.05.2020 14:58 # 11
[QUOTE = muratgulen07] there is no problem in the shoot, does it have anything to do with yakt very yakyo turbo? [/ QUOTE]
My brother is guessing from the turbo because I did not give the turbocharger, fuel consumption increases, soon the vehicle will drop
08.05.2020 14:58 # 12
[QUOTE = furkan] 50 TL in the city, 3rd gear is very rare, always 1 and 2 stop and I make 250 km out of town I made 480 km with 50 TL outside the city [/ QUOTE]
I think the turbo is exhausted anyway, the common problem of the peugeot diesel is the turbo problem .. your vehicle should make at least 20 lira and 150 km in the city, you should rest.
08.05.2020 14:58 # 13
Faruk
If the vehicle's traction is good, there is nothing to be stuck in my head, because I have a little whistling sound but there is nothing in the traction, by the way, my pug is 90 thousand ...
08.05.2020 14:58 # 14
sevozgur
I also have a slight whistling sound, but only at speeds of 20-50 km / h. It is interrupted when it exceeds 50. For example, I can hear it very clearly while driving at low speed in the morning silence. They said normal in the private service. Vehicle 1.6 110 hdi. Anyone hear anything like this?
08.05.2020 14:58 # 15
Oktkor
The day I changed the air filter last year, I started to hear the sound as I passed home. I showed it to a few masters, the sound is quite normal. They said this is a turbo sound. I said why did not he come to this day, again no answer. Then when I went to my hometown, I took it to another competent master. He said that it is necessary to adjust the balance directly. A slight whistling sound that rises with the revs in 1 2 3 gears and less in 4 and 5. When we look at the turbo pressure speed torque range, it is seen how much torque it produces at which speeds. I guess it doesn't load a lot at high speed. So the sound is less at high speeds.
Anyway I went to Ankara to his master. By speaking to the phone in advance. He said that if we just balance it, we'll handle 70 TL. We went, the propellers were bent, the balance adjustment was missed, the shaft inside was worn, and there was a lot of oil inside. But the car did not fall out of power, like a firecracker.
We finally got a new turbo installed. It was costly.
Let me tell you, the new turbo has a very soft whistling sound. But you have to make an effort to hear it. Those who do not know the car cannot hear. It is not normal to poke your mind, if it is not in the car before or if the sound occurred later. :)
08.05.2020 14:58 # 16
sevozgur
When I go to maintenance, I will show it to the authorized service. But when a person wears it, this voice is crazy
08.05.2020 14:58 # 17
Oktkor
[QUOTE = sevozgur] When I go to maintenance, I will show it to the authorized service. But when a person wears it, this voice is crazy [/ QUOTE]
Those in the service are the supporters of direct replacement. Do not make an urgent decision. There are revisions in big cities. Consider.
08.05.2020 14:58 # 18
sevozgur
[QUOTE = Oktkor] [QUOTE = sevozgur] When I go to maintenance, I will show it to the authorized service. But when a person wears it, this voice is crazy [/ QUOTE]
Those in the service are the supporters of direct replacement. Do not make an urgent decision. There are revisions in big cities. Consider. [/ QUOTE]
The sound came from the steering pump. No problem in the turbo. Now we're dealing with it.
08.05.2020 14:58 # 19
Ahmetaltan
The same whistling sound got to my vehicles. I thought it came from the turbo first. The master said it was a steering pump, not a turbo. I do not know if the steering pump originally took an expensive supplier industry. They hardly recommended the repair. If you share the result, we will get an idea.
08.05.2020 14:58 # 20
Oktkor
[QUOTE = sevozgur] [QUOTE = Oktkor] [QUOTE = sevozgur] When I go to the maintenance, I will show it to the authorized service. But when a person wears it, this voice is crazy [/ QUOTE]
Well then.
The turbo costs more.
