turbo sound
08.05.2020 15:10 # 1
59ice307
slm pegugeot family. friends 2005 model 307xt 1.6hdi 110cm arc at 125000km. after pressing and pulling the gas in my car, there is a growling sound from the turbo. He said, "I will show you in the industry, I said I would go to the long road. What is this sound?"
08.05.2020 15:10 # 2
furkan
My whistling sound comes from the turbo, if its hum is whistling, its balance has escaped, but if it is humming it has a problem with its wheels
08.05.2020 15:10 # 3
How much does it sound after you take it out? It would be much healthier to shoot a video.
Koliva 2011-03-20 10:10:20
08.05.2020 15:10 # 4
59ice307
Slm does not matter, when I press and release the gas, when it falls to full idle, it sounds like a warm click. I will try to shoot and put it on the video.
08.05.2020 15:10 # 5
59ice307
[TUBE] f6a2mhz90n A [/ TUBE]
08.05.2020 15:10 # 6
furkan
My brother, your flywheel is defective on the flyball, is it flickering?
08.05.2020 15:10 # 7
59ice307
yes, my friend has a sound, he is missing a little oil from the crank pad ... or when I was taking these problems, I knew he bought the car from my cousin, he told the room that his master said he would handle it until the clutch change.
08.05.2020 15:10 # 8
furkan
I think it was around 1500 TL in volant failure.
FuRKaN 2011-03-20 17:19:20
08.05.2020 15:10 # 9
59ice307
vehicle 2005 model1,6hdi xt white 125000km full accident no trouble bought first owner 20,500tl ..
08.05.2020 15:10 # 10
furkan
the price is very good for the original vehicle, the accidents start from 20, you get a small expense, you get on for years, you get the best model of boring 307 this engine is used in fort volvo very economical
08.05.2020 15:10 # 11
59ice307
[QUOTE = 59ıce307] [TUBE] f6a2mHz90nE [/ TUBE] [/ QUOTE]
08.05.2020 15:10 # 12
59ice307
slm, this sound can cause sometimes the vehicle started to bother me as if it was a ...
08.05.2020 15:10 # 13
tigerland
If you are a partner soup, go to the new industry intuitive master and the problem will be solved.
is to leave the authorized service. 207cc 206 gti 308. 107, other models that I can not think of have almost all received motor training
Uploaded with ImageShack.us
tigerland 2011-03-30 03:09:07
08.05.2020 15:10 # 14
59ice307
Thank you bro, thank you.
08.05.2020 15:10 # 15
just307
bro, the sound of your turbo is different from what it is like, like whistle, whistle yours sounds more like a blow while the speed is falling, but since the problem is the turbo, the way you should follow is the same.
08.05.2020 15:10 # 16
klas59
Hello friends. I am writing about the sound put up in video format above. I have a 2005 model 1.6 hdi vehicle. My car had the same sound and I used it for about 3 months. I showed this to many masters, including the authorized service. Everyone I showed said this sound came from the turbo and I was unstable because the turbo was only 30,000 km. In the end, I decided to ask the turbo to ask for the turbo because it bored me so much, and I said to the master that if you say that the sound comes from the turbo, if you are completely sure of it and if the sound is cut off after the revision and installation of the turbo, I said disassemble it and the master disassembled the turbo by changing the 3-5 parts and repeating it again. She broke. The result was a complete fiasco the same sound again. my nerves broke down, the master broke down because it took about 3 hours. I have already read that there is an electric circuit that controls the turbo somewhere. He came to my mind and asked the master if there was such a circuit. the master said, but he said to me that this sound could not be related to that circuit. and said that the name of the circuit is solenoid valve. I said, let's try it out so that I can feel comfortable and let it go if the sound does not stop. The master said that we will have done a process in vain, but he accepted me from his embarrassment and we replaced that valve with a new one under the engine, we lowered the car from the lift, we started it. who is the master here? me or master :) Anyway my problem is solved after all. The reason for this sound is that the solenoid valve is changing, you should be informed and it is only 5 minutes to change the price to 150 lira. goodbye.
08.05.2020 15:10 # 17
metin
class59 brother please can you open a title to introduce yourself when you become a member. You must fill in your profile information.
08.05.2020 15:10 # 18
nil_car_67
my brother press brake pad flywheel at change
08.05.2020 15:10 # 19
Ali
It has nothing to do with the turbo.
08.05.2020 15:10 # 20
HLTYLMZ
It has been a long time since the subject is open but I agree with the class59 problem seems to be in the westgate valve, as if the valve that adjusts the blade angles to the turbine does not perform its task properly.
Respects
Page : / 2
