Turbo Replacement, Warning Lamp and Performance Low
08.05.2020 20:00 # 1
serhatiktisat
Hello Dear Forum Members,
I would like to briefly summarize my concern. I bought my car 3 months ago. While everything was fine for 1 month, the performance of my vehicle decreased incredibly 1 day. My master turbo said it was broken and the supplier industry installed a turbo. We were not satisfied with its performance and we had the turbo repaired and repaired. I did not get the old efficiency in this. Now, while driving on a long road at a certain speed for a certain period of time, the warning lights on the picture turn on and I get an ESP failure and immediately follow the message "Engine failure please have your car repaired. All the warning lights go out after a certain period of time and cranking a few times. These warnings Do you think it may be related to the changing turbo? Maybe the low performance performance may be due to the turbo that has not been repaired well?
sonerkyl 2016-10-17 15:29:33
08.05.2020 20:00 # 2
My kid is missing a turbo. I wish I had your old turbo repaired, I don't know how it was. The warning messages are most likely a situation related to the turbo, you should connect it to the computer and look at the malfunction codes.
08.05.2020 20:00 # 3
serhatiktisat
Soner Bey,
Thanks for your valuable comments. This way I'm going to my mechanic again. let's see if anything can be fixed?
08.05.2020 20:00 # 4
KILIC
[QUOTE = SafranAtomotiv] Hello dear members, I left the master title at the Peugeot authorized service and opened a shop for myself. Contact: 0541 646 6013 Özkan master. [/ QUOTE]
What is this friend or you wrote the same thing all over. If you did not recommend a solution to the problem of 1 of our friends.
08.05.2020 20:00 # 5
KILIC
[QUOTE = SafranAtomotiv] You are right but my phone can call friends who have a written problem and get healthier information thanks for your message [/ QUOTE]
You are right, but if you write the solution to the problem, they can easily benefit the future friends.
08.05.2020 20:00 # 6
kansu533
Dude, I had the same problem with you, I had a zero original turbo, although the turbo was closing itself from time to time, traction was falling. At the moment, even though I went to 200-210, I couldn't find the reason, but the turbo was turning itself off when it turned out to 130, and the traction returned to normal when it stopped and restarted the vehicle.
08.05.2020 20:00 # 7
kansu533
By the way, you know, in the picture below, it smells like a job that missed turbo, but I still have the same. They still couldn't solve this problem.
08.05.2020 20:00 # 8
noscream
I experienced this incident as follows, my master (relatives) while doing general maintenance, your turbo has a problem, you will go a long way, let's do not cause a problem on the road, the turbo has been sent for repair! Until this time, there was no indication for this problem in the car! Anyway, it was repaired (600 lira) I bought the car from the service, I went to the country without any problems, I said let me take a look at the engine! I saw the same image with this look, I looked at it with surprise, I explained the situation to the master, he said nothing to me! I couldn't trust it, I showed it in my country. I took the risk and on the way back, the vehicle failed and did not exceed 2000 cycles, it started signaling without stopping! We turned, we found a master, while opening the hose with metal clip on the far right of the turbo and looking for maintenance, a nut fell from inside! We saw that the nut holding the propeller was dislodged, the engine would have run out if it ran away (this was also the cousin because of an unfamiliar master, the engine had eaten the same model). Now we use it without trouble! I mean, it's not a normal situation, a good master finds it very comfortable, but it's hard to find that master! Or go to the authorized service and make a fault detection, so rest your mind! I NoScream 2017-07-18 14:54:53
08.05.2020 20:00 # 9
hzr206
I think you will be able to put your turbocharger smart on your mechanic. In any case, it is better to have the gaskets checked.
