turbo question
08.05.2020 14:07 # 1
ErkanKurnaz
I'm going to ask you a question about the turbo, but can you send a picture of the turbo?
08.05.2020 14:07 # 2
hasimayaz
hasimayaz 2009-12-21 22:35:30
08.05.2020 14:07 # 3
307 1.6 hdi benm turbo, the aluminum protection's screw comes out from its place, would it be a problem?
08.05.2020 14:07 # 4
ErkanKurnaz
There is oil leakage and air incontinence in the area I am circled with. the screw that I showed with the arrow has become too loose. how can i tighten it? what are your suggestions
08.05.2020 14:07 # 5
hasimayaz
Roll your finger to the back of the stud. you will feel the head of the screw with your finger. It has to be a torq bolt. if you find it hard to get in with the L torq key. Remove the rubber tube leading to the flow meter on the side, it will make some space.
08.05.2020 14:07 # 6
ErkanKurnaz
thank you Haşim brother first I need to find a L torch key
