turbo problem hk
08.05.2020 18:51 # 1
wedat5401
friends, I bought my car 1 month ago that I bought in very difficult conditions and I couldn't break it, 15 days later my car burned the turbo, I changed the turbo, zero turbo was installed, but it sounds normal from my car at 2000 and 3000 revolutions, is that normal? Or are the wearing masters wrong or is there a deficiency? After the turbo was installed, the oils changed or something, but when I get on the car, there is a sound that rises in parallel with the engine speed. I showed it to 4-5 masters. Is the sound coming normal?
08.05.2020 18:51 # 2
qqyyxx
Of course, it is not normal for the voice that comes after the change before it changes. it is useful to look at a person who understands it.
08.05.2020 18:51 # 3
Orcun.Dmr
It is normal if there is a whistling sound coming from mine Thumbs Up
08.05.2020 18:51 # 4
ENES 307 HDI
In the reply of my friend. The intercooler has not been cleaned most likely and there may be a problem with the air flowmeter. Most often it cuts cars at 3000 rpm. At that moment, the engine protects itself. If you experience black smoke, have egr checked.
08.05.2020 18:51 # 5
wedat5401
ENES SISTER THANKS FOR YOUR ANSWER, I HAVE MANY EXPENSES. IF I DO NOT DO THAT THEY SAY? I KNOW THESE INTERMEDIATES
08.05.2020 18:51 # 6
ENES 307 HDI
If the vehicle exceeds 3000 rpm, keep using it, but if the turbo valve is oiling there, I recommend you at least have it checked. Did you change the bidet oil filter after the turbo?
08.05.2020 18:51 # 7
ahmet_bjk
The turbo normally operates with a whistling sound. Are you sure you don't mess with that voice?
It also makes a different sound when the turbocharger hose comes off or when air leaks out of my place. I recommend you check the turbo hoses. If the vehicle is not accelerating enough in the working cycle of the turbo, the hose is out, accelerating, but if it makes a different sound, it is leaking air from somewhere.
If they install the side industry of the turbocharger hose, the material used can sometimes be hard and open holes to leak air.
08.05.2020 18:51 # 8
wedat5401
Thank you for your interest, there is no problem with the cycle, but the higher the speed I use, the sound increases, if there is any problem in the vehicle, the vehicle malfunction must be burned.
08.05.2020 18:51 # 9
wedat5401
There was no change about the hoses, I bought the turbocharger, the turbocharged hoses were used,
