turbo problem
08.05.2020 14:52 # 1
black206
Hello there,
207 1.6 90 hp. When I pressed the gas from the turbo a few days ago my car started to have a whistling sound. The new turbo prices in the market range from 650 TL to 1600 TL. In repairs, they range from 300 to 600.
What is your suggestion ???
When the repair is done, it is said to be a maximum of 6 months. some of the people I interviewed say garret, ihbo
Thanks......
08.05.2020 14:52 # 2
black206
Let me add that the rubber at the end of the turbo intake pipe is deformed and the shattered sound started after that, but I did not change it ...
08.05.2020 14:52 # 3
serkan24577
I don't know if you wait for your turbo mouth, no one should take it to my head, I took a car before I took my car, they said the turbocharger of the car was a motorbike, the engine is burning oil, black smoke is coming from the exhaust, the service is 3000tl.
08.05.2020 14:52 # 4
deniz_206
turbo breakdown costly god wersin convenience.
08.05.2020 14:52 # 5
arifziyaar
In April, the 1.4 turbocharger of my 1.4 hdi 206 was malfunctioning.
08.05.2020 14:52 # 6
the whistling sound comes from every turbo brothers bored
08.05.2020 14:52 # 7
xMEGANx
I have a turbom that does not whistle? : D is good if there is: D
08.05.2020 14:52 # 8
delta0o
If it comes too much, there is a definite problem.
08.05.2020 14:52 # 9
black206
The sound is beautiful :)
After a while, the turbo will remain in our hands ...
08.05.2020 14:52 # 10
[QUOTE = black206] The sound is beautiful :)
After a while, the turbo will remain in our hands ... [/ QUOTE]
efecim you start the vehicle, unplug the turbo hose from the snail, close the mouth of the pipe with your hand. If someone else is loaded on the gas, if the suction is strong, don't be afraid, but if it does not suck DANGER 1500 change the oil of the tl regularly, use the vehicle cycle unconsciously burns too much, the turbo breaks down when the gear shifts, it comes from the whistle turbocharged, sometimes the ambulance sounds. sounds like
08.05.2020 14:52 # 11
badcombatant
With my 1.4 hdi 307 vehicle, I had to travel 1200 km without interruption due to the funeral, but I used 10,000 km in the city, but it didn't draw my attention, but the turbocharger was cut between 2,000 - 2,500 revolutions, there is no problem in my vehicle, black smoke oil. like burning, falling from traction
I hope there is nothing in your vehicle's turbo
08.05.2020 14:52 # 12
[QUOTE = badcombatant] I had to travel 1200 km without interruption due to the funeral with my 1.4 hdi 307 vehicle, but I did not draw my attention as much as between the cities but the turbo was cut between 2,000 - 2,500 revolutions, it is not a very important thing. no trouble black smoke like burning fat burning
already turbo faulty vehicle faints serial burns too much smoke throws
08.05.2020 14:52 # 13
master
[QUOTE = polatkaptan] [QUOTE = badcombatant] I had to travel 1200 km without interruption due to funeral with my 1.4 hdi 307 vehicle, but I did not get my attention so far, but the turbo was cut when the whistle was more important than the 2,000 - 2,500 cycles. I guess there is no problem in my vehicle, black smoke like burning fat, falling from traction
Could that sound come from the alternator ball or belt?
Do not mislead you ..
there are many balls in that area. Steering pump, coil etc.
I also thought I was wrong and turbo defective, Alternator tensioner set came out.
08.05.2020 14:52 # 14
osterreich
After my friend came 1900 km without stopping for permission, the same voice started to come from my car, I took the authorized places to me, the peat was broken like I told you, I did not shake it, I continued to drive (but there was no problem in my vehicle) 1 week later, the problem emerged clearly. that whistling sound has been replaced by the belting of the belt. It cost 400 euros. After the change, the sound continued to be heard, the malfunction was understood. I spent 200 euros. + Work done here. Now everything is normal. I think it is difficult for you if the turbo is broken.
