Turbo oil problem.?
08.05.2020 16:40 # 1
ozknckr
Hello friends,
Today I opened the hood to put the wiper water in it .. Then I looked inside the engine .. The turbo is the oil there, that is, the pin comes down when the car is running. . I wanted to ask the forum ...
08.05.2020 16:40 # 2
delay
When I said I looked inside the engine, would you please explain in more detail where is the pin coming down?
08.05.2020 16:40 # 3
ozknckr
It is not a pin :) I am throwing a picture now
08.05.2020 16:40 # 4
ozknckr
< br>
What is this piece leaking oil?
08.05.2020 16:40 # 5
qqyyxx
It looks like a turbo oil hose, the other day I had the same problem, they changed to 162 rubles in the service. I couldn't get along very clearly from the picture, & nbsp;
08.05.2020 16:40 # 6
delay
my brother is looking at the lubrication pipe that enters the turbo ... or the pipe has a gasket on it .. I will say that the pipe is bursting but the pipe is usually there is an isolated section. The pressure of oil may come to turbo, the necessity of loosening in the gaskets or in the inlet section may be because the oil is at the highest pressure because of the high pressure oil ... let the butterflies go, they will cost more & nbsp;
08.05.2020 16:40 # 7
oguzhan29
I could have been kidnapping the turbo's lubrication pipe that had been in my car
08.05.2020 16:40 # 8
turbo27
in any way, if the turbo air leaks oil from the pipe, the turbo is broken, but don't miss out on the oil intake record on the turbo & nbsp; If there is a fault then it is not a turbo, it is a problem with the record bolt connections.
08.05.2020 16:40 # 9
ozknckr
Thank you guys for the answers .. I came back to Istanbul tomorrow, if fortune will come to the service .. Thank you very much ...
08.05.2020 16:40 # 10
toga406
Get well, did you solve the problem?
08.05.2020 16:40 # 11
gayetnormal
Hello. I did not want to open a new topic. But while I was checking the car today, I saw oil there, which is located on the underside of the turbo and moves up and down when pressing the gas. I think there's enough oil to drip. It is 2012, but when I saw the picture, I realized that the place was the same. I wonder what exactly was your problem and how did you find a cure. Let's not look at the master's mouth, then they should not say that the turbo will change. You can see the pictures of my vehicle below. Can you answer friends who can help? & nbsp;
gayetnormal 2016-02-19 12:38:55
08.05.2020 16:40 # 12
iclturkey
I had the same problem. It doesn't come to neglect, it kills the turbo.
I bought the original piece on 22.10.2018 for 240TL. Workmanship I paid 150 TL.
Apart from that, I had the engine underwash for 50 TL.
It cost 450 lira. :(
08.05.2020 16:40 # 13
ozanhdi
WHERE TO PROVIDE LUBRICATION PIPE
& nbsp; DO YOU RENEW THE BOLTS AND COPPER PLUGS IN THE PIPE?
Reviews
08.05.2020 16:40 # 14
ozanhdi
WHERE TO PROVIDE LUBRICATION PIPE?
& nbsp; REPLACE BOLTS AND COPPER PLUGS IN THE PIPE?
I LOVE YOU IF ANSWERS :)
