Turbo launches late
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Boxer
08.05.2020 21:11 # 1
Konyali
2014 model Euro 5 engine pevgeot boxer brand when I press the filled gas, it eats little gas until two thousand times, it enters the turbo after two thousand cycles, and when I open the car a little bit, it protects itself from three thousand cycles, it recovers again when the ignition is turned off and who says it is turbo or vesget or From the diesel pump or the air flow meter or the installation, all of these have not been a year yet, except for the alternate installation ... there was no point-shooting master, maybe I thought it happened to you.
08.05.2020 21:11 # 2
Well, I was controlled by my teacher turbo solenoid valve. Of course, your engine should have 2.2 hdi, probably in your vehicles. sometimes it may cause incorrect connection of the hoses coming to the valve.
08.05.2020 21:11 # 3
akk0212
My vehicle was going to malfunction at 3000 rpm. I changed the turbo solenoid valve.
08.05.2020 21:11 # 4
Konyali
Mr. SONER, thank you very much, at least I have a piece to check my mind. Thank you very much. You are very kind.
08.05.2020 21:11 # 5
Konyali
Thank you very much, thank you.
08.05.2020 21:11 # 6
Konyali
One of the reasons why it makes sense to me is that after the transmission malfunction is resolved, it is useful to try what you said while standing still.
08.05.2020 21:11 # 7
You're welcome. Then the master who made the gearbox may have forgotten to plug in one of the disconnected sockets. or could not sit properly.
