TURBO Installation in 10 Steps
08.05.2020 13:59 # 1
Friends, the title may be easy for you, but when it comes to the turbo assembly sequence, 10 steps can become 10 steps for you for a period of 2 months and 3 months even longer ...
1.Turbo oil inlet pipe and outlet pipe will be blinded
2.The oil of the engine will be poured, new oil will be added again, the engine will be run with half a gas for about half an hour.
3. Meanwhile, the pressure of the oil pump will be checked.
4. If the engine has any other malfunction, it will be fixed.
5. Engine oil will be poured again, leaks will be checked, if there is chips, new oil will be added again and the same process will be repeated.
6. The holes of the blind oil pipes will be opened and connected to the turbo, the oil pipes will be thoroughly cleaned and air will be kept, silicone or liquid adhesive will not be used in the gasket areas.
7. Original turbo oil recommended by engine manufacturers will be used. the oil filter will also be replaced.
8. Original air filter recommended by engine manufacturers will be used and hoses will be cleaned, if any, the intercooler radiator will be cleaned with chemical substance.
NOTE: Compressed air will not be used when cleaning the air filter and will not be used when cleaning the hoses.
9. We will start our engine after these processes. After the vehicle starts, the gas will not be pressed for 10 minutes, it will run at idle, when we stop the engine, the engine will be operated at idle for 3 or 3 minutes, it will be stopped.
10. It is absolutely wrong to install a turbo on the road to the vehicle stuck due to turbo malfunction. After the vehicle has been taken into service and the above operations have been done in order, it should be mounted in the turbo.
NOTE: This article is compiled as a result of extensive research and is for information purposes. No liability is accepted in any way. Good Forums ...
Burak GÖZAL
08.05.2020 13:59 # 2
Health brother in your hands
Here is the Peugeot Turkey difference
Like others, copy, not paste, handcraft information, these are undersigned like lions.
There are copy and paste, of course, but there is always a source or thank you for underlying respect for labor
Happily we have such armed members
Forever Peugeot Turkey
08.05.2020 13:59 # 3
sinan-s
Maşallah burak.Eline health
08.05.2020 13:59 # 4
thanks for your effort
In the summer, I used this information for my internship book, then I said to God bless me :)
08.05.2020 13:59 # 5
iLLeGaL
Thank you for your good health and sharing.
08.05.2020 13:59 # 6
[QUOTE = MELİH] sagLık labor
[/ QUOTE] Summer or winter does not matter ... If the person's job has been seen, if he has knowledge, it is enough for us and increases.
08.05.2020 13:59 # 7
barabelli
mrb friends.I live in a small district.I am 60 km from the center.There are 1 repairmen here and they do not understand the new vehicles from diesel vehicles.2 months evel turbo changed yesterday when I came from the city to the county, the exhaust from the exhaust started to emerge smoke, traction has gone, I threw myself hard into the district. The oil is finished sideways. As soon as I arrived, I ordered a turbo today and it will come tomorrow.
08.05.2020 13:59 # 8
pusutr
I don't think the turbo assembly is easy as written.
08.05.2020 13:59 # 9
[QUOTE = barabelli] mrb friends.I live in a small town.I am 60 km away from the center.There are 1 repairmen here and they do not understand from new vehicles from diesel vehicles.2 months evel turbo changed yesterday when it came from the city to the district, it was difficult to come to the district from the exhaust when it came to the district. 4 liter of oil in the engine ran out side by side. As soon as I arrived, I ordered a turbo today and it will come tomorrow.
If you are going to do it yourself for the first time, I suggest you not to struggle. I recommend you to take it to the master who understands this job.
08.05.2020 13:59 # 10
Oktkor
You can't do it, hodja.
