Turbo hose keeps coming out. |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 18:23 | # 1 |
ahmet_bjk |
The turbo hose of my 2008 model Renoult Kangoo 1.5 dci was broken. No matter how much we tighten the clamp of the newly attached hose, the hose comes out. What can I do. The picture of the part is below, the tip to the left of the hose in the picture comes out. Thank you... ![]() |
| 08.05.2020 18:23 | # 2 |
Alicilik |
The gray band varya brother took the wraps from the Americans wrapped around him and left a lot with a wrapping. |
| 08.05.2020 18:23 | # 3 |
I'm not entirely sure, but the pressure of the turbo might be too high. There was a similar problem in the focuses, the turbo could be removing the pipe because it couldn't adjust the pressure.
| 08.05.2020 18:23 | # 4 |
ahmed206 |
[QUOTE = Mesut48] I'm not entirely sure, but the pressure of the turbo might be too high. There was a similar problem with the focuses, the turbo could be removing the pressure because it couldn't adjust the pressure. Maybe it will explode somewhere else if it doesn't come out. Maybe I say because I don't know much about the working principle of turbo.
| 08.05.2020 18:23 | # 5 |
There must be a rubber seal inside that pipe, otherwise you should get it from a reno particle and install it with it otherwise it will not stay in place.
| 08.05.2020 18:23 | # 6 |
ahmet_bjk |
[QUOTE = qqyyxx] There must be a rubber seal inside that pipe if you don't have it, you should get it from a reno particle and install it with it otherwise it won't stay in place. [/ QUOTE] yes there is a rubber gasket first it came with a rubber gasket and now the gasket is left. |
| 08.05.2020 18:23 | # 7 |
then you will need to buy a new one of that seal. deformed over time.
| 08.05.2020 18:23 | # 8 |
ahmet_bjk |
hose and gasket new already replaced because the old one cracked |
| 08.05.2020 18:23 | # 9 |
ahmet_bjk |
I guess it was this time we put on the gasket of the old part and tighten it again. |
| 08.05.2020 18:23 | # 10 |
It was the sub-industry that you attached later. I hope the event has been solved.
| 08.05.2020 18:23 | # 11 |
ahmet_bjk |
yes, the shape of the original was different, the master said this would not happen, we had to have the supplier industry installed. |
| 08.05.2020 18:23 | # 12 |
The hose is a sub-industry and may become too loose. Or the nail / notch / protrusion may be worn where you attached the hose. Or you are pressing a lot of gas.
