Turbo Hose Crack
08.05.2020 16:46 # 1
marmarascorpion
Hello Friends,
I had been seeing drops of oil on the floor just under the radiator in front of my vehicle for about 1 month, wherever I looked the next day when I parked the car, there was 4-5 drops of oil on the floor. I took the vehicle to the mechanic today, the turbo hose is worn and cracked, it says 250 lira, it should have changed, it came to me a little more: (& nbsp;
Can I get your comments, can I find a more suitable place in Kagithane?
08.05.2020 16:46 # 2
turbo27
I know that there is no intercool in 1.4 hsi, the possibility of oil coming from the bottom may be from elsewhere, besides, if the turbo hose breaks out, the pressure wind after 2500 cycles on the road & nbsp; does and the traction becomes low, we have to look well ..
08.05.2020 16:46 # 3
marmarascorpion
[QUOTE = ezelefe] The same problem started with me in the new
the week we have got, let me see the master of the peugeot murat. it was in my mind that he is making changes, just selling parts. Reviews
08.05.2020 16:46 # 4
feline
You gave me 250 TL more and renew the turbo. It came to me a little too much. The hose price got zero turbo to 600 TL.
08.05.2020 16:46 # 5
toga406
I think there is a remedy for the hose. On the name of the hose
I do not understand how the oil passes through that hose, the oil leaks
08.05.2020 16:46 # 6
marmarascorpion
Turbocharger is a lubricating pipe, the market price is 60 - 70 TL of this pipe 180 TL of workmanship is too much for me.
08.05.2020 16:46 # 7
oguzhan29
my brother ask our sponsors, I changed the turbo lubrication pipe because it missed the oil.
08.05.2020 16:46 # 8
loiz
ne hose friend .. yeah i changed the hotrum between the turbo and the air filter was 75 tl.
08.05.2020 16:46 # 9
turbo27
If the record is cracked or punctured, yellow welding is done 10 TL, while the workmanship is 50 TL ... stop by if you are at work, all of them work for 1 hour ..
08.05.2020 16:46 # 10
taskin
Turbo lubrication hose was broken in me. I gave 50 TL of hose + 50 TL of workmanship. The catalyst part of the vehicle was inserted and inserted again. Even if it is not a hard job, it takes a maximum of 1 hour. 250 TL like a lot ..
08.05.2020 16:46 # 11
sahin-peugeot
[QUOTE = turbo27] If the record is cracked or punctured, yellow welding is done 10 tl, if workmanship is 50 tl..av. I know that the record cannot be funded & nbsp; It's not worth risking the turbo for a 50 lira piece
08.05.2020 16:46 # 12
marmarascorpion
The piece is square-shaped, some of this pipe used to be made as a steel tether, now it is all made as a metal pipe . In the form of a tether and leaking oil from me. ezelefe meanwhile Sahin Peugeot was in Umraniye, I think the Master Master is close to him, how much workmanship he wanted for change.
08.05.2020 16:46 # 13
turbo27
It does not penetrate easily, it is not pierced, the record is entering the turbo or the copper washer from the block is missing, check the connection bolts first.
08.05.2020 16:46 # 14
marmarascorpion
sagolasin for your interest in ezelef, but i can not go on weekdays, let me ask a master here.
08.05.2020 16:46 # 15
marmarascorpion
The tool I have built today, it takes a little bit to change the pipe, it's a small tube above & nbsp; :) but it takes about 2 hours to remove the & nbsp; catalyst, so it took about 2 hours. Peugeot Orjinal
100 Lira = Labor + 1 Lt Oil
& nbsp;
I paid 170 lira in total.
08.05.2020 16:46 # 16
spesial
Hello, the same problem appeared to me, unfortunately. My vehicle is 1.4 HDI & nbsp; 2005 model 206 model. How can I get the turbo oil pipe? I couldn't find it when I searched for spare parts sites. I don't know if I called wrong. & Nbsp;
08.05.2020 16:46 # 17
Serkan
You can contact our sponsor Şahin Peugeot
http: //parcasor.sahinpeugeot .com /? @ = new
0216 631 10 80
0533 301 88 06
08.05.2020 16:46 # 18
spesial
Thank you Serco
08.05.2020 16:46 # 19
serhatisik01
Hello friends, I have been a member of peugeot turkey yet but I was following as a guest for a long time .. I have 2005 1.4 206 HDI. About 2 months ago, I was also smoking black smoke when I went to the mechanic, he said, the turbocharger hose had to be drilled and changed, and I bought a 30-cylinder new hose. I hope you don't have to pay a lot of money.
08.05.2020 16:46 # 20
Serkan
Turbo air hose with 30 TL and sub-industry 30 TL, turbo lubrication hose that a friend is looking for
Page : / 2
