Turbo does not start.
08.05.2020 19:19 # 1
R.CaVuS
Friends 3 days ago, I disassembled the air flow meter of my vehicle and signed it with thinner. After installation, the vehicle turned on the engine fault light, gave an antipolution fault error and the vehicle turbocharger was not engaged. So it fell a lot from the performance. What's wrong with me? The flow meter is broken, the turbo is broken. But I never played with the turbo, why should the turbo break? When I connected it to the computer, it gave an error called low air intake. We deleted the error and nothing improved.
08.05.2020 19:19 # 2
xmen
teacher did you do the cleaning yourself?
08.05.2020 19:19 # 3
R.CaVuS
Yes, I did it myself and washed it with thinner.
08.05.2020 19:19 # 4
korkusuz202
thinner may have damaged the wires inside. There is a flow meter in my hand.
08.05.2020 19:19 # 5
R.CaVuS
Let's talk from the private
08.05.2020 19:19 # 6
Alicilik
Replace the flow meter without eating the turbo. Why did you log in if that was so? The flow meter is not cleaned .... They have a mechanism that takes already filtered air and has extremely sensitive receptors.
08.05.2020 19:19 # 7
korkusuz202
[QUOTE = R.CaVuS] Let's talk specially [/ QUOTE]
I replied to your message ..
08.05.2020 19:19 # 8
FTH
Turbo has a plug in there, like the customer, you can disassemble it and make it from it ..
https://encrypted-tbn1.gstatic.com/images?q=tbn:and9gcqxhmqx7uwnnv6yzc6hgmhewngk7ubmumnr74oislgqoox1ote-t to
08.05.2020 19:19 # 9
demir2001
Clean and install the pad with cleaning spray again. The same thing happened to me. I used an oil cleaner after your error occurred. Get well soon
