Turbo circumference is black
08.05.2020 21:06 # 1
whisky
The friends have a bit of black work on the upper side of the vehicle on the stove. I checked it with my hand, not oil, not liquid, soot we know. I wonder what this causes, the problem is the loss. Vehicle 2006 407
08.05.2020 21:06 # 2
GokhaN
Hello, the only place I think you can do work on the engine side is the manifold outlet, there is oil inside the turbo because it does not work
08.05.2020 21:06 # 3
whisky
Then you say there is no situation caused by turbo. Is it usually the case or is there a problem even if it is a manifold?
08.05.2020 21:06 # 4
GokhaN
[QUOTE = whiskey] You say there is no turbo situation. Is it usually the case or is there a problem even if it is a manifold?
Cars are getting old, oil may be related. If there is nothing wrong with the traction, there is nothing you need to do urgently.
08.05.2020 21:06 # 5
whisky
While accelerating, the revolution makes a slight stiffness when it comes to 1800e and then continues its normal acceleration again. Significantly when accelerating in 2nd and 3rd gears.
08.05.2020 21:06 # 6
fatih__
Can anyone help if they know the same thing in mine? what is the definitive solution?
