Turbo charge
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 20:11 # 1
Bahri
Hi friends my car 2013 model peugeot 301 1.6 hdi diesel is my problem error code. P2563 turbocharger compression control position sensor `A` circuit range / performance. the light sign is lit.It does not light at the normal speed, that is 120.140 km.
08.05.2020 20:11 # 2
Oktkor
I do not exceed 150, I think.
08.05.2020 20:11 # 3
Bahri
[QUOTE = Oktkor] Do not exceed 150 I think. [/ QUOTE] dear friend, my goal was not to speed up, I did it because of an emergency.
08.05.2020 20:11 # 4
Oktkor
I understand.
08.05.2020 20:11 # 5
I think there is a problem with the turbo. It may be because of not having enough pressure in the tub at high speeds and speeds or because it is leaking. Have the turbo hoses checked and before the turbo, my teacher, how many kilometers of the vehicle are you now and where do you get the fuel.
08.05.2020 20:11 # 6
Bahri
Hodja, I checked the hoses and I am taking the fuel from opet at the current km 97 thousand.
08.05.2020 20:11 # 7
I throw at a speed of 140 km, there is a considerable pressure difference between the pressure in the vehicle that makes 3000 cycles and 4500 cycles at a speed of 180 km. The best thing is to have the turbo checked in a solid turbocharger.
08.05.2020 20:11 # 8
Bahri
Sir, I think that if there is a leak in the cracked old gaskets and hoses, there will be a leakage of oil. I did the intercol test. There is no problem.
08.05.2020 20:11 # 9
Just as I was here, I looked at some foreign forums with purpose information sharing.
08.05.2020 20:11 # 10
Bahri
[QUOTE = Bahri] I think that if there is a leak in the cracked old gaskets and hoses, I think there will be a leakage of oil. I have done the intercol test. No problem here. I solved it. No matter how I checked the hoses and sockets, I couldn't find a problem. I also replaced the turbo right hose. I also cleaned the sockets with the pad cleaner. The problem was corrected and I tested and got a positive result. Also, as a note they said the original price of the pejo turbo hose was 140 TL. I bought ford connect turbo hose. get
08.05.2020 20:11 # 11
Trelof
hello friends i have 301 2013 too. After 15 km of road, I stop at the lamps. I get up slowly in 1st gear, then the engine is on fault light. I get the Turbo Charging Error when I connect it to the computer. What is the reason ? Can anyone help?
08.05.2020 20:11 # 12
[QUOTE = Trelof] hello guys I have 2013 301 too. After 15 km of road, I stop at the lamps. I get up slowly in 1st gear, then the engine is on fault light. I get the Turbo Charging Error when I connect it to the computer. What is the reason ? Can anyone help? [/ QUOTE]
I need to take it to a good tubist, and let's try to help if you wrote exactly what the error code was.
08.05.2020 20:11 # 13
Trelof
Thank you, my teacher, I did not get the code, but the turbo charge error I read on the pc was writing. You are right, maybe the error code is required, but it is interesting to do it when I get up, not when I accelerate. Do you think it will cause big expenses?
08.05.2020 20:11 # 14
In other words, we cannot necessarily say from tubo, but my teacher may cause many reasons that can cause him. maybe in a simple problem. I guess I didn't eat gas on the first departure, so I checked the air meter and turbo solenoid valve.
08.05.2020 20:11 # 15
Trelof
Sir, let me tell you, I use shel fuel continuously, I usually buy the same shelden, I don't know if there is anything to do, but I bought a 50 lira diesel from another shel. I visited the next day, no problem. I woke up in the morning, I run the car for a while, I wait, I do not move immediately, I waited, I waited 15 km I made the road. We stopped at the lamp, stood when it got up, I thought the fuel was exhausted, I looked at the screen, the engine fault light pulled right to the right, I ran it, it was not extinguished, whether it was fueled or not, the engine malfunction light, took it to the mechanic, connected it to the computer, it was writing a turbocharger problem, they deleted it. The next day I went to work, for example, I did 10-15 km after work in the evening while coming, I went to pat lamps while getting up and burned. Again, we put the same fault light off. They will look thoroughly, I have not left the master yet
08.05.2020 20:11 # 16
Trelof
The error code is passing as p2562 p1497.
08.05.2020 20:11 # 17
[QUOTE = Trelof] The error code is passing p2562 p1497, why is the car still at 66000 km [/ QUOTE]
There is a related issue, there are explanations about error codes.
find a good peugeot master and hotrums etc. need to look. the curve may be clogged.
08.05.2020 20:11 # 18
Trelof
My teacher does not enter the turbo vehicle, I am not using the car I will take to a turbocharger right now. He is lying in front of the house, we looked at him with a friend who understood more than yesterday. I will find a good master in Bursa. Do you know where you call Egr?
