Tube and exhaust on the same side
08.05.2020 20:41 # 1
onklc06
Selaymun alaikum sentence. Inspection is approaching and my tube and exhaust are on the left. I do not know exactly what is going on in 2018 inspection rules. Do I have to take the tube to the right? What is done for this? What kind of a path is followed? It is the first time I own a scuba car, I do not know much about it. Thank you from now
08.05.2020 20:41 # 2
Hello, brother. However, the pipe and exhaust will not be on the same side. You have to take the tube to the right.
08.05.2020 20:41 # 3
RP393
According to the current legislation, the lpg filling nozzle must be on the right side and mounted on the bumper. Unfortunately, it does not pass in the suspended under the vehicle.
08.05.2020 20:41 # 4
onklc06
[QUOTE = sonerkyl] Hello, my brother. However, the pipe and exhaust will not be on the same side. You need to take the tube to the right. [/ QUOTE]
For this, is there a project or brother or can the master pass directly to the other side? I remained so because I didn't know much about the tube
08.05.2020 20:41 # 5
onklc06
[QUOTE = RP393] According to the current legislation, the lpg filling nozzle must be on the right side and mounted on the bumper. Unfortunately, it does not pass in the suspended under the vehicle. [/ QUOTE]
Thank goodness for him on the right side, which is beautifully mounted on the bumper, which makes no trouble
08.05.2020 20:41 # 6
onklc06
actual
08.05.2020 20:41 # 7
RP393
No need for a project, hodja. You can change as many places as you want in the luggage. Project is only required when changing a tank or cylinder.
Also,
If there is a spiral hose in the copper pipe that goes from the bottom, they want to see clearly that there is no attachment in the copper pipe.
Have a filling nozzle on the right and in the bumper.
Make sure you have a coffee table under the warehouse.
Nothing else is needed. RP393 2017-12-22 22:22:54
08.05.2020 20:41 # 8
onklc06
[QUOTE = RP393] No need for a project, hodja. You can change as many places as you want in the luggage. Project is only required when changing a tank or cylinder.
Also,
Nothing else is needed. [/ QUOTE]
Thank you very much, teacher, good evening
08.05.2020 20:41 # 9
x571
[QUOTE = onklc06] [QUOTE = RP393] No need for a project, hodja. You can change as many places as you want in the luggage. Project is only required when changing a tank or cylinder.
Also,
Thank you very much my teacher, good evening [/ QUOTE]
When ready, put the filling nozzle next to the tank cap. It is cleaner and easier. No problem I have lost the filling cap, if you put a simit tank instead of a spare tire, there is no problem that you cannot enter the LPG since the filling input is not visible.
08.05.2020 20:41 # 10
onklc06
[QUOTE = x571] [QUOTE = onklc06] [QUOTE = RP393] No need for a project, hodja. You can change as many places as you want in the luggage. Project is only required when changing a tank or cylinder.
Also,
There is no problem in it, my master refill cap is mounted very nicely on the bumper. It is the only point that is not stuck in my head.
