TRY IT AND SHARE HERE
08.05.2020 15:02 # 1
marasov
Confused YES FRIENDS 1.9 DIESEL PARTNER 2001 MODEL
HOW TO SPEED 100 KM SPEED / SPEED RANGE IN 5 GEARS AT 3000 RPM
08.05.2020 15:02 # 2
reserpin
I think there is a problem with your vehicle, I have passed 100 in 3000 revolutions in the 3rd gear.
08.05.2020 15:02 # 3
Faruk
[QUOTE = reserpin] I guess there is a problem with your vehicle, I am over 100 in 3000 revs in the 3rd gear 160 to 5th gear [170] [/ QUOTE]
the difference comes from 1.9 D 71 hp (without turbo) to 1.6 110 hp + turbo + high torque.
08.05.2020 15:02 # 4
The same thing will happen if you attach the same transmission to each other ...
The power face speed ratios do not change with the power difference. Replaces the difference between transmission and differential
08.05.2020 15:02 # 5
Faruk
[QUOTE = cecoli] The difference of transmission ratios, not power ... If you attach the same gear to each other, the same thing will happen ...
I learned this too Sırıtma
08.05.2020 15:02 # 6
oguzhan29
brother my old car 2003 model 1.9 flat (without turbo) berling sat room same 5th gear 3000dd 110km / speed
08.05.2020 15:02 # 7
[QUOTE = Faruk] [QUOTE = cecoli] Because of the difference of not the power transmission ratio ... if you attach the same transmission to the same thing, the same thing will happen.
If you can be useful to someone, how happy :))
If you need to explain it, let's say that if you insert the engine of your vehicle and put it in a 200 hp engine, the speed and face ratio will not change.
For example, if you are doing 3000 or 6000 rpm in 5th line, you will make those smileys again, but what is the difference?
the difference is during acceleration. Acceleration is different. Let's say for example, if you do 0-100 acceleration for 12 seconds, you will do it in a shorter time with 200 hp engine or your intermediate accelerations will happen much faster ... I hope I can explain :))
