TROUBLE LAMP FALL SWALLOW
08.05.2020 19:42 # 1
Baver Diyar
Good evening guys. Yesterday I took a short trip from Malatya to Elazig, 25km after I got off the road, the malfunction lamp turned on and gave the depollution system faulty error. Since I had encountered this situation before, I did not wear it, after 2-3 minutes, the vehicle fell from the traction and it did not exceed 3000 rpm. I pulled it to the right, I gave the gas at idle, and the 3000 rpm did not exceed. In this way, I went to Elazig, the same problem happened again when returning, the vehicle did not exceed 3000 cycles, it was cured when it closed. I came to Malatya, put the car in the car park in this way, I got in the morning and I traveled quite a lot until the evening. malfunction lamp did not light up depollution system faulty error did not come out no problem in traction what do you think i should do right now
08.05.2020 19:42 # 2
ismailkaya
exhaust emission system malfunction
08.05.2020 19:42 # 3
seiko35
They had the same error in me. They said they were at the air flow with the egr valve. I did not put the fuse of the fuse on the fuse panel.
08.05.2020 19:42 # 4
Baver Diyar
thank you teacher . I did not show the vehicle I used today, I did not show it to any service.
08.05.2020 19:42 # 5
seiko35
I know that the diesel filter changes when the road is made for 10000 km.
08.05.2020 19:42 # 6
seiko35
If the diesel filter is obstructed, it may cause a drop in the shrinkage. It may also cause the egr valve to dry or it may rupture in the air tank sensor and flow hose or something.
08.05.2020 19:42 # 7
Baver Diyar
I do not think it has changed for me since 3 thousand km since I bought the vehicle. I will change the diesel filter tomorrow.
08.05.2020 19:42 # 8
KRATERYA
Fill the tank from the shell nitro, maybe it can do once again until the diesel is completely gone. The engine shuts itself down so that the diesel filter does not damage the diesel engine when the sulfur rate in the diesel is high.
08.05.2020 19:42 # 9
Baver Diyar
I changed the diesel filter, the traction of the vehicle improved and I started to get the diesel from the shell. But today it gave the same fault again. The master connected it to the computer again, said the air flow sensor, we removed it, we cleaned it back, we put it back, the vehicle's well got better.
08.05.2020 19:42 # 10
seiko35
I said, my brother, because of the air flow
08.05.2020 19:42 # 11
Baver Diyar
Exactly, if my teacher did not improve with cleaning, we would have to buy the price 383tl
08.05.2020 19:42 # 12
boran04
I think it's from the fuel filter, I personally lived. it changes when it changes ... of course the problem may differ I could not exceed 3000 cycles.
08.05.2020 19:42 # 13
seiko35
So how do I fix it?
08.05.2020 19:42 # 14
mhmtclb
I bought the same error after I got LPG, I went to LPG service, they said that they made adjustments, they moved from the fuse panel and now it does not give any error but a muffled sound like exhaust started to come from the exhaust and the hammer fell off. Also, if you can not lift the car in one go and stop, the car will not work if you do not hold the starter for 10 seconds. They don't say in vain that LPG master will be fine
