Trouble control for 307 window control
08.05.2020 19:06 # 1
Faruk
Hello friends
I have been in the vehicle for about 6 years and since I bought the windows from the driver's window control, the windows are not getting up or down.
I open a little something, then when I press the lift it goes down completely.
I changed the remote once, it was fixed for 3-5 months, but the same thing happened at the end.
service says this happens when water enters, oxidation is opened and cleaned but then it is the same.
Last time we opened it together, we sanded the card in the service but nothing has changed.
After the last rain, while the vehicle is opening and riding, water drips and now it is opened, paused and closed.
what are you doing when you encounter such a problem?
my friend had 2004 307 and there was no such problem, he had taken a second. So the previous owner did something and got rid of the problem.
I'm waiting for your help.
08.05.2020 19:06 # 2
byderebey
I mean, as you say, the water is failing as I get it .. I changed it to every ride with a napkin.
08.05.2020 19:06 # 3
Faruk
This is the biggest problem of the 307 for me, but there must be a solution.
There are those who have no problems, we have to solve the problem no matter how they solved it.
08.05.2020 19:06 # 4
xmen
I had the same problem for now, only when he lowers the glass. There is no problem when I remove it. LOL
08.05.2020 19:06 # 5
BLACK LION
normal Sleepy It would have happened in the previous one. No need for water to enter. It prevents the keys from pressing between dust, dirt and particles. It is clear that after all, a human isolates underneath it, right? When I start to arrest, I usually remove it twice a year with a cotton swab and alcohol and put it back. Do not apply sandpaper or something, you will draw the printed circuit and it will not work. The places you need to erase are the bright conductive areas where the keys on the circuit come from and the corresponding black dots on the silicone part. You can do it yourself. Just be careful not to open the clips when opening.
08.05.2020 19:06 # 6
sinka251
The inserts that touch the electronic card lay down its conductivity, so the buttons do not work, there is a material called conductive carbon paint. sinka251 2015-02-15 12:52:52
08.05.2020 19:06 # 7
pekmez006
Remove the remote control on the door handle, the card is difficult to open, carefully open it carefully, remove the card, wipe it with cologne or alcohol, and dry it and install it.
08.05.2020 19:06 # 8
Canberk35
Unfortunately, this problem exists on all of the 307's controls. I have it in my vehicle. When the new controller is bought, it causes the same problem after a while. Opening and cleaning the inside is a very short-term solution for me. It turns into a glass that opens again after 15-20 days but does not close. The problem stems from material quality. If you open it and look at it, you can see that the silicone interiors of the mirror adjustment part are made of metal, others are probably made of carbon or other poor quality material. That is why the round button with the mirrors never loses its condition. The keys that open and close the glass are broken even if zero is taken.
As mentioned in the subject, the pads that take conductive carbon paint or conductive silver paint and press the circuit in the silicon and provide the current need to be painted. By the way, it is quite difficult to find these paints. The electrician-electronics shop I did not visit in Izmir, I still did not find it. Even most of them say, "What is it?" I got reactions like.
If there is a friend who can find and apply from these paints, please share his experiences with us. This is an issue that bothers me a lot.
08.05.2020 19:06 # 9
sinka251
[QUOTE = Canberk35] Sorry, this problem is present on all 307 controllers. I have it in my vehicle. When the new controller is bought, it causes the same problem after a while. Opening and cleaning the inside is a very short-term solution for me. It turns into a glass that opens again after 15-20 days but does not close. The problem stems from material quality. If you open it and look at it, you can see that the silicone interiors of the mirror adjustment part are made of metal, others are probably made of carbon or other poor quality material. That is why the round button with the mirrors never loses its condition. The keys that open and close the glass are broken even if zero is taken.
As mentioned in the subject, the pads that take conductive carbon paint or conductive silver paint and press the circuit in them and provide the current must be painted. By the way, it is quite difficult to find these paints. The electrician-electronics shop I did not visit in Izmir, I still could not find it. Even most of them say, "What is it?" I got reactions like.
[/ QUOTE] My friend who is very hungry, the mirror direction buttons are not carbon-coated, so it is not broken, so replace this monetization method with a new one. We let it dry for 1 hour. Before using the material, we shake it well. sinka251 2015-02-16 00:06:59
08.05.2020 19:06 # 10
oguzhan53
If the new 207's control fits 307, there is no problem with them.
08.05.2020 19:06 # 11
Faruk
friends, thank you all.
You are right, I realized that the mirror is different with the glass controls.
This carbon conductive paint is worth 6-10 TL in the net, so it is worth trying.
But will we apply this paint to the black parts of that silicone that press the circuits on the remote.
in the product on the net,
shall I order
http://www.marketdijital.com/ıletken-karbon-boya,pr-991.html
Faruk 2015-02-16 10:22:30
08.05.2020 19:06 # 12
Canberk35
Yes, teacher. That is the product mentioned. And there are those who have a higher quality and a price of 3-4, not carbon, but silver. Frankly, I don't know how much it will matter. I think carbon is also worth trying. I couldn't find it. I'm going to buy now.
The application will be made to the black pads in the silicone part of the remote, which completes the circuit, as you say. I have seen similar problems in different tools on the Internet, implementing this method and getting positive results. Drive as thin as possible. They say that if necessary, you will take another layer after drying.
Another method is to cut and paste small aluminum foil on the same pads. Again, there are those who apply this method and get positive results. But I see this method a little more risky. If the desired result is not achieved, the controller may be completely garbage. Nevertheless, you should have thought of it.
08.05.2020 19:06 # 13
Canberk35
[QUOTE = oguzhan53] If the control of the new 207 fits 307, there is no problem with them. How can we take it from it?
I thought the same thing. In most of the 207s, only the front two windows are automatic. Backs are manual. 4 glass automatic models have different socket structures. I also examined the 308-407 models. Their sockets are different. Even the sockets with and without makeup in 307 are different. I think Peugeot has worked specifically so that one does not fit the other. :)
08.05.2020 19:06 # 14
Faruk
thanks.
I will order at the first opportunity.
I will open it when the weather improves a little. I will share the result here.
I am waiting for your result in you.
