triptonic problem or indicator
08.05.2020 14:04 # 1
fatih1903
good morning yesterday yesterday I encountered a problem when my car was on triptonic 2003 307 xr VITES P when I wanted to pull it to D when I pulled the display flashed R, but I think the vehicle went forward so I think there is a problem in the indicator because if I shift the gear forward, back and forth go back, there is no problem in it. give friends bored cnm, this is the situation. It is not a problem caused by the brain. Good day without accident and failure :)))
08.05.2020 14:04 # 2
fatih1903
Come on, let me wait for your comments. Thank you .. :)
08.05.2020 14:04 # 3
hasimayaz
did it once or does it constantly?
08.05.2020 14:04 # 4
fatih1903
He did it last night on his way to work this morning. What did you say?
08.05.2020 14:04 # 5
hasimayaz
If you think of every burning light in the pejo, the man will not have a head. The ground ends its life .. I do not think it will make it from the indicator. There are small electro valves in the auto regulator or the pressure regulator on the gearbox. There may be a lack of contact with them. However, the automatic gearbox can make a definitive determination.
If it is up to me, leave where iraq stay, continue until it is rooted.
08.05.2020 14:04 # 6
fatih1903
eywallah, master master, i will die too i guess dewam hehhee until death :)
