TRIPTONIC LOCKING
08.05.2020 15:13 # 1
ismail ozdemir
307 Triptonik AGENTS HAVE MEMORIES gear changes in, for example R DEN VEHICLE STOPPING D YE've served my REFER D INSTALLED kalýyo ECRU Zealand N yazıyo AND TRANSMISSION HANDLE LOCKS gearbox IC TELE LIKE BISEY HAVE TO NORMAL ONU my BASTIRDIGI with ELI FREEZES BUT THAT in this way normally YACHT BOYLE BR experiencing the problem oldumu HIC
08.05.2020 15:13 # 2
metin
NOT NORMAL.
FROM THE GEAR HANDLE TO THE TRANSMISSION MAY BE TROUBLEED FROM THE END OF THE WIRE. WE HAVE DISCONNECTED WHEN THE OIL WAS REPLACED, THE HAND WAS NEVER WASTED.
THE PREDICTED MAY BE TRACKED IN THIS PIECE. THERE IS NO IMPOSSIBLE TO LOCK THE HANDLE WITHOUT EXTERNAL P MODE.
08.05.2020 15:13 # 3
ismail ozdemir
I understood that there is a problem in the wire, as soon as I think it is right on the top of the box, I clicked on it, and the gear is already done. There is such a problem with the vehicle, I need to change my wire.
08.05.2020 15:13 # 4
metin
Call 0532 296 96 49 avni master helps. He is an automatic transmission master.
08.05.2020 15:13 # 5
revolutionary26
[QUOTE = text] NOT NORMAL.
Is locking in the P position like this? We wait for the vehicle without stopping. We pick it up at P, then it locks without going into any gear without starting the vehicle again. I just bought the vehicle and this happens occasionally. I just went 70 KM but Gülme
08.05.2020 15:13 # 6
metin
[QUOTE = revolutionary26] [QUOTE = text] NOT NORMAL.
good luck first.
Now, when the vehicle is in p position while running, the automatic lever kits are;
When the vehicle is running, you get out of the vehicle and the children do not leave p if they take the arm to d. When you get into the vehicle to take it out, you press the brake. the operator under the brake pedal unlocks the lever, then you shift into gear. They did it completely for safety, but because the sender under the brake is stiff, sometimes the lock doesn't unlock even if you press the brake. As a solution, you will stop and restart the vehicle or change the brake sensor for approximately 50 TL.
08.05.2020 15:13 # 7
revolutionary26
[QUOTE = text] [QUOTE = revolutionary26] [QUOTE = text] NOT NORMAL.
good luck first.
thanks. I read this in the user manual. Actually, it doesn't bother to give 50 TL yet :) then maybe I can get it :)
08.05.2020 15:13 # 8
metin
exactly.
When I run in the morning, I wait for it to warm up and when I get out of the car, I heat it in the n position, I take it from there and walk. but if anyone else in the vehicle is dangerous to do what I do.
08.05.2020 15:13 # 9
ismail ozdemir
There is no problem in me, there is something like a wire at the top of the suspect, the tip is red.
08.05.2020 15:13 # 10
lamazibici06
I had had it with great negligence.
