Triptonic Gear and Fuel Consumption
08.05.2020 14:16 # 1
pug307_26
Arkdaşlar I use a 307 Triptonic transmission. Dil Çıkarma
That's why I shared it with you, friends. What exactly is the logic of confirming this even in the catalog data that triptonic transmissions consume more fuel than manuell transmission? Why so much fuel
consumes? Isn't it the case to shift into 5 gears manually on long road, to 4th gear on triptonics and not to change gear? Since the gear interspaces are different and there are 4 gears, it can be explained that it consumes a lot of fuel in the city, but what is the logic of the event on the long road? Can we share the fuel consumption of the friends using the 307 gearbox types and share them as reference with real values? I am very grateful to everyone who has already been interested in the information already interested, I would like to thank everyone Göz Kırpma
pug307_26 2010-06-02 13:01:30
08.05.2020 14:16 # 2
BAHTIYAR
I can not cope with 307im triptonic gasoline. I have a lpg, but if it is running cyclically, if the gear gears are large, for example (for ford taunus), the engine at 1 speed rotates 1 turn while rotating 5 gear is economy gear ratio is 0.82, the engine makes 0.82 rotating one turn, regardless
08.05.2020 14:16 # 3
ErolSen
Mine is that the auto gear is 10 liters per 100 km in the city, so 360-370 thousand per km. We had a steering wheel coach I knew that if you use auto gear cars by rooting the gas, it burns very little. it becomes durable. When it comes to the long road issue, as long as I remember it is almost as close as manual in auto gear, for my vehicle it was 6.5 lt outside the city in the catalog and 6.1 lt in manuals, so the difference is felt in the city.
08.05.2020 14:16 # 4
Onur
In automatic triptonic transmissions, the gear intervals are longer, for example, in the same gear of the same vehicle, the 5th gear 110 km speed engine speed 3000. automatic 4th gear 110 km speed engine speed 3000. According to the automatic vehicle manual, the vehicle burns more ramps on the ramps and depending on this, the vehicle burns more in the city. it balances but has high consumption in the city
08.05.2020 14:16 # 5
selcukcivelek
Hello, I have a 2006 model vehicle, I bought the 307 sw, and as soon as I get the tank full, I am testing it right now. Avoid sudden braking, try to travel at 100 120 km speeds, and do not let the needle move very fast. my humble idea.
