triptonic 307
08.05.2020 14:15 # 1
narkotik71
I just bought the vehicle, friends. I sometimes have trouble for him. For example, when the car is normally in park position, I turn the ignition. There is no click. I am not trying again. Then I wasted and started and started. It does not always happen. It also works. If it stays in position, this time the arm is fixed, it does not move, it does not switch to d position, I stop and run it again.
My mate ..
08.05.2020 14:15 # 2
saw50
I do not understand the problems of the vehicle, but I think it would be useful to see a service.
08.05.2020 14:15 # 3
selcukcivelek
Did you find a solution to your problem?
08.05.2020 14:15 # 4
haruncoskun
should not be taken to the authorized service as soon as possible
08.05.2020 14:15 # 5
selcukcivelek
I definitely recommend the service. I have the same case with me.
08.05.2020 14:15 # 6
hello my friend. i have 307 triptonics as well. if the gear is still locked. There is a small part called brake mists under the brake pedal. It means that it is defective. Services are changing to 50 TL and it will be like 70 TL with labor. I hope I could help.
08.05.2020 14:15 # 7
i forgot to tell my friend as far as i know you have to start at p.d or neither does it work anyway.
08.05.2020 14:15 # 8
metin
[QUOTE = narcotic71] friends I just bought the car. I sometimes have trouble for it. For example, when the car is normally in park position, I turn the ignition, there is no click. I don't try again. If it stays in the park position for 3.5 minutes, this time the arm is fixed, it does not move, it does not switch to the d position, I stop and restart it.
My mate ..
You have to press the brake to open the arm lock for security. When you press the sensor below the brake pedal, it sounds like a click and the lock is unlocked so that you can move it out of position p. (They did so that the children inside the vehicle do not move to the d position while the vehicle is working in p.) But because the client is a little bit, sometimes it does not open the lock when it stops and restarts it. If you go to the city, allah bless) I will change the sender as soon as possible. I have no idea about not working while at p.
08.05.2020 14:15 # 9
metin
[QUOTE = ayhan_55] I forgot to tell my friend you need to start the car as far as I know. D and n won't work anyway. [/ QUOTE]
It works in both p and n, but it only gives warning when it is running in n. It does not work in r and d.
08.05.2020 14:15 # 10
BAHTIYAR
If it does not pass even though you press the brake, it is the customer, but in the system that locks the gear lever, there may be a problem.
08.05.2020 14:15 # 11
emin15
as if there is a problem with the gear position switch
