Trip computer
08.05.2020 17:31 # 1
Gokhan Cetin
First of all, friends, I bought 307 vehicles 2 weeks ago. postimg.org/image/uopt04xy7/
this line computer does not write how much fuel is going on line 3, it doesn't react when I press the keys
2 questions are
http://postimg.org/image/4uklo3nbz/
< div> what is the number of km of the vehicle in the picture below
sql98 2013-04-12 23:40:30
08.05.2020 17:31 # 2
Alicilik
I think it belongs to you in two photos.
On the middle screen, the trip computer data changes with the button on the wiper arm end.
The 14km phrase in the first photo should be the way you can go with the current fuel, but it may be wrong. The second possibility is the path you traveled after you reset the trip computer data. There are no other d options: D
If that button does not work, how did you get to the second photo position because you can get to that menu by pressing the button. I think that programming part is set to give a warning at a certain speed
08.05.2020 17:31 # 3
Gokhan Cetin
sorry i forgot to write this is not my car 1.4 diesel without headlight and rain sensor in mine
08.05.2020 17:31 # 4
Gokhan Cetin
I know that I don't have a wiper
08.05.2020 17:31 # 5
Alicilik
If I think you have received Xr, some models do not work because the trip computer has a screen but there is no button and the system is not turned on.
In the 307s, the part that rotates on that wiper tip is completely removed, and if you say you are replacing it with the button or you get it, you can change the com2000 box and the arms completely. If they connect pp2000e and activate the trip computer after the change, you will not be able to access the information.
08.05.2020 17:31 # 6
Gokhan Cetin
Alliance Thanks a lot, it goes beyond me: D
08.05.2020 17:31 # 7
Alicilik
[QUOTE = sql98] Charm Thanks a lot of things that goes beyond me like this: D [/ QUOTE]
Appreciation is not really hard work for you.
08.05.2020 17:31 # 8
ahmet_bjk
1) If you press the key and there is no change on the screen (if you are sure that you press the right key), there may be a problem with the lack of contact due to oxidation in the key. I think you mentioned the numbers on the counter. That number does not appear exactly in the picture, but it is likely to be a clock ...
08.05.2020 17:31 # 9
Ozgur
km from the moment you reset the first picture.
The second picture is the km you have done so far from the moment you reset the 'trip computer' data.
08.05.2020 17:31 # 10
Gokhan Cetin
My free friend is not mine in 2 pictures, 14 km which is in the 2nd picture does not show in my car. Does anyone know what is the duty of the miners?
