trip computer
08.05.2020 16:34 # 1
m1976k
friends Can I have my 307 me trip computer bought and I wonder how much it costs me?
08.05.2020 16:34 # 2
Alicilik
Is there any 307 without trip computer and cruise control or still "Dead"
My teacher 3 lines < br>
You need to have the screen. In addition, key modification should be made to the tip of the wiper arm.
In some 307s, the tip of this arm should be changed completely, while in others, a rod and a button can be made. These are available in the forum. If requested, I can provide detailed information.
If these are not available, information should not be found, and the nearest pejo service should be visited and activated with PP2000.
Also, the price of Şahin pejoda cruize arm, which is one of the sponsors of our site, is very active and both are active. you can get the taste of xt.
08.05.2020 16:34 # 3
m1976k
dear hcm display 3 lines as in the picture above, but I would be glad if you give detailed information on the end of the signal arm.
08.05.2020 16:34 # 4
m1976k
how is this modification performed? I am waiting for your answers with longing.
08.05.2020 16:34 # 5
Alicilik
Sir, I made you wait, I'm sorry.
Try as here. If it happens, continue. If not, it is likely that the tip or the arm will need to change completely.
08.05.2020 16:34 # 6
m1976k
I examined the form, but the tip of my arm does not seem to be fixed, I am afraid to break it too hard because I can not be sure that it can be removed.
08.05.2020 16:34 # 7
Alicilik
could you remove the one like that on the button part?
08.05.2020 16:34 # 8
m1976k
Unfortunately, as if the cover did not look like a cover, I tried to remove it. I could not force it too much.
08.05.2020 16:34 # 9
Alicilik
I understand. Then you will have to find the arm with the com2000 button and replace it from the rotating part to wiper. Or you'll have to disassemble the steering wheel and replace all of the com2000.
08.05.2020 16:34 # 10
m1976k
If I can remove it from the rotating part for the wiper, at least when I click from there, I can see if the trip computer is working but there is a spring mechanism in that arm & nbsp; it provides spraying water on the back glass.
08.05.2020 16:34 # 11
Alicilik
[QUOTE = m1976k] If I can remove it from the rotating part for the wiper, at least when I press it, I can see if the trip computer is working but there is a spring mechanism in that arm & nbsp; It provides spraying water on the back window. If I swallow it, it would be a dream to call the service guys today. The guys are talking about 1500 2000t. 1500 2000tl? & Nbsp; What are they doing my teacher, God's sake?
com2000's zero 300-400 bits on the screen, 400 workmanship 200 get 1000tl, what does this service in the head of? What is it in the service? You go to a location that uses pp2000 and activate it. Service money trap.
There is no luggage sign on the confort models of 206+. I had it at the authorized service. The men have not squeezed the chassis completely. The car failed. I went back, he said from the tape without looking at him, with nothing to do. Then I went to a random master, looked at the man, took 30 seconds, tightened, take the back screw, brother said. Here is the service, I directly complained the authorized service to the person who opened it and closed it.
08.05.2020 16:34 # 12
teoman_40
I think the brothers do not disassemble, I disassembled it was broken, holding a very thin nail with 4 legs. Somebody broke, then it was like it was idle when I put it back in it. 17 "border =" 0 "alt =" C o nfused "title =" C o nfused "/>
08.05.2020 16:34 # 13
fatihgg
Is there anyone who can do this heat 206 excluded? I think the application is only at 206.
08.05.2020 16:34 # 14
gngburak
I did 206, it was perfect, I even damaged that arm button quite a bit
, but I changed it with the key on the other side of the signal, it was very solid.
08.05.2020 16:34 # 15
fatihgg
[QUOTE = gngburak] I did 206, it was perfect, I even damaged that arm button very well
but it was very solid, I changed it with the key on the other side of the signals on the other side. thank you very much it worked for me. -computer-com2000-tu-do "target =" _ blank "rel =" nofollow "> http://forum.peugeotturkey.com/forum_posts.asp?TID=16691&title=peugeot-206-yol-bilg Bilgisayar-com2000- tu-yapm
yes it is a perfect operation, but there are 307 people who try this system, the arm is technically the same structures of pain. back then wow come to our carpet. okay in 206, so 307, did i run like that?
08.05.2020 16:34 # 16
[QUOTE = fatihgg] & nbsp;
& nbsp;
yes, he's a perfect operation, but is there anybody who tried 307, this system is the same as he's in a tricky pain. is that happening in 307, did I run like that?
It happens the same way. Just know how the connection is on the arm and take action accordingly.
